chong67 Android Expert Apr 23, 2014 #1 I am getting my Pad next week. Can anyone recommend a good wall charger for it? I like to have a few for convenience. It has to be 2.1 amp or more?
B bigmac11 Newbie Apr 23, 2014 #2 The stock charger is 1.8 amps. I've also used a Nook charger labeled at 1.0 amps and it works also just takes a real long time +8 hrs.
chong67 Android Expert Apr 23, 2014 #3 I go to ebay and Amazon to look and there is no mention of any OEM LG charger. I think I might just get the OEM USB charger for Note 3 ?
K KOLIO Guest Apr 23, 2014 #4 chong67 said: I go to ebay and Amazon to look and there is no mention of any OEM LG charger. I think I might just get the OEM USB charger for Note 3 ? Click to expand... If you're wanting LG branded chargers,the one for the G2 is the exact same charger. Amazon.com: LG OEM Home Wall Travel Charger AC Power Adapter USB Cable for LG G Flex - LG G2 - LG Optimus G / G Pro / G Pro Lite - LG Google Nexus 4 / Nexus 5 - LG Optimus F6 / F7 / L9 - LG Optimus L9 - LG Lucid - (Comes with Accessory Case): Cell Ph BTW,it's a 1.8A charger.
