Record own ring tones
stonefox
Member
I would gern create my own ring tones and have downloaded several with built-in editor. Most of them have a button labeled "Record now" and I press the button I come to the "Voice Recorder" - I make a recording, and will then automatically return to the editor, but get this message "ist er ikke kunne edit files of this type .3 ga "- how do I change my recording, so it gets recorded in a second format?
Is there another "Voice Recorder" which is better?
I previously had installed a program that is always asked if it was a ring tone, notification, I would make, and record the correct format and store the following in the correct directory on the phone, but can ikkr remember what it's called.
Help wanted
What format is the voice recorder saving in? I did that on a BB once and it saved as an AAC file. Most of the phones I've had will use MP3 or MID for ringtones. The BB did use AAC - I wanted a silent ring for spammers so I just recorded a minute of silence.
There are converters.
