Hi all, been a great fan of this forum and had some much info/help from.
I have a Vodafone HTC Magic (32B)
I rooted it and installed the Hero Rom, I used the unlockr method
I used flashrec-20090815.apk and recovery-RAv1.2.1G.img to root it, which worked fine.
I used Qteknology Hero (WWE Dump) for G2 Magic-Voda 32B v1.6 Swap for the ROM, which worked fine.
However upon using the Hero ROM, I wasnt happy with it so wanted to get rid of it and go back to original or maybe use another version of the Hero ROM.
I selected the "format SD: fat32+ext2+swap" option from the system recovery, yes I know silly me. I wasn't fully concentrating when doing it
Now my phone keeps rebooting the Hero screen until I take out the battery.
I can get to the system recovery and the fastboot usb screen, lights are working also. So I don't think it is bricked.
As my phone keeps resetting I can not get my SD Card to mount so I could add the OTA files to the card.
I even installed the USB driver from the SDK package, to see if it would work that way. But to no avail.
I can not access the drive from command prompt either.
I have searched on here, but cant seem to find someone else who has experienced this problem.
Any help would be greatly received.
