Redmi Note 7 reboots automatically when playing something at 90-100% volume in phone speaker
I am facing a weird problem. When my phone plays a video from any source at 90-100% volume it reboots automatically. Below 90% it works fine. Even when I connect an earphone it works fine too. Problem doesn’t exist when it’s connected to power. It only occurs when its not connected to power.Phone calls via speaker works fine too. It only causes problem when I play something from say YouTube, spotify or Facebook at 90-100% volume. It just reboots automatically.
Your device may have a built-in safety feature preventing speaker damage, which is a good thing to have.
You wouldn't want your speakers blown, would you?
Personally I never keep my media volume up that high, ever.
It shouldn't be doing that. But that fact it only does it when not connected to a charger, that could be the battery is failing and needs replacing, or there's some other fault?
Try replacing the battery?
I haven't tried it yet, I bought a new phone.
Exactly I am facing the same issue right now with my phone Note7
Whenever connected to charger none of the problem arises but normally Even I Increase volume higher or my brightness higher more than 80% it gets off....I don't know the reason yet..so if you have a solution to it yet please do respond
