Apps Referenced Libraries missing in project
Cryptic79
So, I set up the environment like Devolio said in the XP install (I'm running Vista, though). I created a project just to do a "Hello, World." app. I notice that I'm missing this folder.
What went wrong?
I'll watch the video tonight and see if I'm missing anything. Any idea if this is fixable without reinstalling stuff?
Honestly man I ran Vista and had so many freaking problem on every level that I switched to Ubuntu... I did have it working on vista originally but without seeing how you installed it hard to so for sure... and yes should be fixable without a total re-install probably something very simple that was overlooked...
EDIT... took another look think you need to add this : import android.hello.R;
if you still can't get it to work after adding that line go to the irc channel and i'll walk you though it....
