Help Regarding problems with downloading apps from the galaxy store
Somdatta
I got a new Galaxy M40 today (I am posting on this forum since M40 is not showing up in the dropdown menu on my browser) and when I tried to install something as simple as twitter, it got installed but then unless I update it from the Play store it's not letting me access it. It's saying that the app is not of the latest version which in my opinion is bollocks, for there's no reason the Samsung app store should be hosting outdated apps. I don't want to enter play store because I don't trust Google. Please help. I am attaching the screenshot of what I said at the beginning.
i6GDQNE
When you say "it's not letting me access it" what exactly does that mean? The phone won't open the app or, more likely, the app won't connect to the service? If the latter that is entirely down to Twitter, and would indeed imply that Samsung are hosting a version of the app which Twitter have deprecated (or rejected for other reasons).
If you tell us what app version it is someone can confirm whether it's the correct one. Or you can do as Danny says and look in apkmirror.com to see what the latest version they have is.
Ok so what happened was after I downloaded the twitter app a popup came up at the bottom after I logged in saying that I have to update the app and there was no other option other than that to start using twitter. And when I clicked on that it directly went to play store. So either the play store way or the highway, this is very undesirable.
How do I figure out the app version? Also what is this apkmirror? Can one bypass play store using it?
apkmirror.com is a website that keeps a curated archive of android apps (in the apk format used for installation). Now in general I'd avoid downloading from random websites as you've no idea what they might insert into the apk, but these guys do a pretty good job of only including official copies, nothing pirated or cracked, no letting third parties upload apps to their site, and I've never heard of a problem from there.
As for the popup taking you to the Play Store, you could try selecting the Play Store app in your app manager (that's what Samsung used to call it - it's Settings > Apps on non-Samsung devices, but Samsung always change their menus) and seeing whether it has any defaults set. If so clearing them might mean that in future it will ask you which app you wish to use. But it's quite likely that Twitter themselves directly coded a pointer to the Play Store, in which case there is nothing you can do if it happens again except ignore it and find an update yourself.
As for how you find the version, in most apps if you look in their settings there is an "about" option which will tell you the version number. Or if you look in your app manager, select the app and look at its information you should find a version number in there.
