I couldn't find a post where anyone else had remapped the old voice search hard key and I was getting a bunch of force closes, so I did a simple remap to make it a second system search button. I am using this with BrokenOut Rom 1.1
USE AT YOUR OWN RISK!
I am assuming you know how to use ADB - MAKE A BACKUP FIRST!!!!!
1. Download the attached file and unzip.
2. "adb connect (your device)"
3. "adb push surf_keypad.kl /system/usr/keylayout" ****Note Below***
4. Restart phone
****Note****
If the surf_keypad.kl is not in your ADB root folder you will need to enter the location to this file instead of just its name.
Simply repeat the above with the stock surf_keypad.kl I have included to return it to stock.
**Posted edited to clarify wording.
4. Restart phone
****Note****
