T
Tagg09
Guest
Hello,
I am new to android, but I have been able to fix most of my problems through apps or tasker. I have to problems that I have not been able to find a way to fix.
1. Google reminders do not trigger if the screen is off. They do not appear in the notifications area or anything, the time passes and there is nothing. If the screen is on, even at the lock screen the notification pops up, but not when the screen is off. How can I fix this?
2. The voice commands for the timer do not work. I am using 4.4.2 KitKat, and all the research I've done said this problem should have been solved. I can tell the device to set a timer for X minutes and it will open the timer, but the timer stays at 00:00 and it does not start. Is there a way to fix this, or should I just hope for the next OS update to fix this?
Thanks for your help.
