Dima Gusyatiner
Steps taken:
Anybody can help with the issue please?
- Bought Zenfone 5 (A500_KL).
It comes with all shitty Asus apps, so I decided to upgrade to Android 5.0 (Lollipop) and Root (to remove all Asus shit later).
- OS upgrade went fine.
I used official downloads (asus.com/Phone/ZenFone_5_A500KL/HelpDesk_Download).
- When trying to Root phone (using this tutorial: ibtimes.co.uk/how-root-zenfone-5-android-5-0-lollipop-v3-23-40-52-one-click-tool-1505424)
I get this error:
Code:' ' ' Connect your device with your computer and prepare to ROOT ' ' !!! DO NOT DISCONNECT USB CABLE WHILE ROOTING !!! ' ' Press any key to continue . . . ' ' ' Rooting, please be patient .. ' ' target reported max download size of 661651456 bytes sending '/system/bin/resize2fs' (6 KB)... OKAY [ 0.006s] writing '/system/bin/resize2fs'... FAILED (remote: Security device, flash function is disabled.) finished. total time: 0.015s target reported max download size of 661651456 bytes sending '/system/bin/tune2fs' (1386 KB)... OKAY [ 0.048s] writing '/system/bin/tune2fs'... FAILED (remote: Security device, flash function is disabled.) finished. total time: 0.069s target reported max download size of 661651456 bytes sending '/system/bin/partlink' (2940 KB)... OKAY [ 0.098s] writing '/system/bin/partlink'... FAILED (remote: Security device, flash function is disabled.) finished. total time: 0.123s ... FAILED (status read failed (Too many links)) finished. total time: 170.146s < waiting for device >
