Help Remove hold (pause) icon during call?
  • Start date Start date
A
Android Question
Guest
Hello all, I am new to android and I have a small issue that is quite annoying. During a call, in the call screen there is a hold (pause) button that I accidentally press very often, and the call gets held, as it should. I know that the phone should lock the screen when I bring it close to my ear, and it does, but somehow I still press it sometimes. I don't know if the problem is that I separate the phone from my face more than I should.. The question is: is there any way to configure that screen so that I can remove the "pause" button? An app that lets me do this, maybe?
I have already disabled call holding with my carrier, but that does not prevent holding it from my phone.
Hopefully I am explaining myself :)
Thanks for any help!
I am running android 5.1 by the way
You'd need to modify the system app to do that.
You could try a different dialer, but I'm pretty sure you get the same in-call screen anyway so don't think it would help.
