Removing old carrier info from an unlocked phone
Daruss
I purchased an AT&T GSM unlocked phone, but I'm using a different carrier than AT&T. Is it possible to remove anything related to AT&T from my phone? For instance, when I go to use my wifi on my phone, I'm asked to check if I want AT&T to automatically connect me with the nearest wifi. Maybe that's not possible, but I wanted to ask to be sure. Thank you.
I don't know LGs very well, but in general there are two ways: using root plus either a custom ROM or manually removing apps, or else reflashing the phone with firmware from a non-carrier version (as long as there is another version with the same radio bands without the carrier branding, and you don't need some special trick to flash firmware from a different version).
Thank you for your response. I'm interested in the reflashing option, but have never done that. How would I locate the available firmware for reflashing?
