Help Removing unused alarms
  • Start date Start date
A
Android Question
Guest
There are just so many simple little things that are either not possible or very complicated/cryptic on my HTC One (4.4.2)... Getting a little fed up.
One such thing is removing unneeded alarms. I am in Clock > Alarms.
There is a big PLUS sign to add more, I can edit them no problem, but how do I remove them ?
Thank you
Press the 3 dots button next to the +, then select delete from the options. Tick the boxes next to the alarms you want to delete then confirm, and it's done.
Pressing the 3 dot (options/settings) button or long-pressing items on the screen are good ways of discovering options in Android.
