A
Android Question
Guest
I have a Pantech breakout. The screen is totally cracked. I bought an almost new one with no SIM or microSD but with a good ESN. What do I need to do to use the new one as though it was the old phone? I have done this with a basic phone but never with a SIM or microSD. Do I just insert the SIM and microSD from the trashed phone (they are in good shape) in the new phone or is there more to it with Verizon? Do I need to follow their online replace this phone process? How do I get the apps saved on my microSD to show up on the new phone? I can always go back to the Play Store and re-download the apps I have but was hoping it might be easier than that.
