Help reset factory settings?
meeshy
Hi
Anyone know how to do a factory reset on a flytouch 3? My user manual says go into Menu, then System Settings and then Privacy and so on. Yet when I press the Menu button, I only have a Settings tab and there is no Privacy tab within in. Thanks
Hi
Hi, i've sussed out how to do it on my flytouch 2 superpad, i'm assuming it will also work on yours, hold the menu button down, then power up, keeping the menu button down until you see "recovery" displayed on screen, then let go, and leave it to do it's thing, be sure to power the device from the mains when recovering to avoid any power out's. icemanuk2
