Dear Android Develop/ enthusiast friends,
Hope you all are all in good health and doing good.
I am basically a Electronic hardware guy with limited knowledge on Android.
With some efforts in last few weekends I could successfully install an Android 10 build into my raspberry Pi 4 single board computer.
This works all right when the Ethernet is always connected.
1. When Ethernet it disconnected it goes into a reset loop and even does not connect to wifi with correct password? Can anybody share how to move forward to solve this ? You can see this failure at the end of the below video link which I posted on youtube.
2. When I start skype it does not connect always, probably because skype for Android always looks for an wifi connection… so it fails to sign me in. Work around >> with skype lite I can log in.
Can anybody guide me how to force skype to sign in using the Ethernet in Android?
In some attempts when I was lucky to connect the wifi and sign in skype.. then it works all right even when I later connect my Ethernet.
Kind regards,
SC
Kind regards,
SC
