Restricting wifi on some applications
Jasmin74
Member
Here s the scenario : I have a wifi manager which allow the user to add a wifi (because I have deleted the original settings on android) - now I need only few applications to use the internet (one of among is a customized browser) & the wifi manager will be among those applications of course.
So, I you want to block internet access from some of the apps in the device & allow it for others.
A firewall app will do it. I'm guessing you are rooted because of the degree of modification here, in which case you have a wide choice to pick from.
That's an unusual requirement in a firewall app - I've never met one that has it.
I suggest using a separate app to lock (password protect) access to it.
THIS FIREWALL CAN BE EDITED BY ANY USER OF THE PHONE OR TABLET.. SO IT IS NOT PROTECTED.
I would think the user of the device would have his own password to the device so no one else can use it or edit.. You Think?
Also it's apps called App Locks that can lock individual apps with a password on your device, so there is a workaround to accomplish what I am assuming you're trying to achieve.
Sir we must be in control of some devices in our institution this is why.
As for Applock , it is very poor even the paid version.
I would totally recommend this one with password protection included, also you can choose what type of connection you want on each of the apps..
AFwall+ is excellent - I would buy it if it's password protected, BUT it is not!
That's odd, I'll have to dispute your claim. As I type this I'm looking at the app's Preferences >> Security menu. There's an 'Enable protection' menu with options to use either Password or Pattern, a 'Stealth mode on pattern' check box, and a 'Maximum number of attempts' option.
This is the view from inside the app..if you wanna get it or not that's your problem..you asked for something, every one already gave you the right answer.
Yes but it s not working! plus you can simply uninstall the app though there is an option to prevent this.
