Root Returning to stock after using AIO Root
gully52
Hopefully, mtmichaelson will see this, and chime in... I've been searching the forums all afternoon without any resolution...
I have a pantech breakout that was rooted and CWM'd via his AIO root recovery pack a few months ago.
I'm getting ready to return it to verizon under warranty and need to get it back to factory. I'm SOOOO close I can taste it, but it's not quite there.
I flashed BreakoutUnRoot.zip
I flashed StockBreakoutPre.zip
I wiped caches
I wiped Data
I booted up the phone, and then successfully installed Stock Recovery
Now when I boot up the phone it tells me there's a software update available but the update fails around 20%, and the phone reboots, and tells me that the update failed.
I've tried doing the update about 4 times with the same result.
I'm unrooted, seemingly bloated, and stock... everything works, but the software update won't take... Am I missing some system apps somewhere that wouldn't have been replaced by the StockBreakoutPre.zip???
PLEASE HELP! :) I'd appreciate it!
Brian
Getting the same issue... but hopefully some additional information can help:
Specifically, the message is:
assert_failed: apply_patch_check("MTD:boot:[a bunch of hashes]")
E:Error in /cache/feta/ipth_package.bin
(Status 7)
InnoPath diff update failed.
