Apps ReverseSnake application has stopped unexpectedly please try again. Please help!!!!!!
mathkid95
I am creating an application called ReverseSnake, which is basically the opposite of snake. In this game, the snake has to avoid the apples.
I am getting the following error: The application ReverseSnake On a Phone(process.shankar.AndroidMaterial.eclipse.Reve rseSn ake) has stopped unexpectedly. Please try again.
I checked my code and xml files and they all look fine. I am running this on the 2.1 Android emulator. I basically used Google's Snake code and altered it.
2010-05-29 09:38:10 - ReverseSnakeTest] ------------------------------
[2010-05-29 09:38:10 - ReverseSnakeTest] Android Launch!
[2010-05-29 09:38:10 - ReverseSnakeTest] adb is running normally.
[2010-05-29 09:38:10 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 09:38:10 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 09:38:10 - ReverseSnakeTest] Performing sync
[2010-05-29 09:38:10 - ReverseSnakeTest] Automatic Target Mode: launching new emulator with compatible AVD 'my_avd'
[2010-05-29 09:38:10 - ReverseSnakeTest] Launching a new emulator with Virtual Device 'my_avd'
[2010-05-29 09:38:18 - ReverseSnakeTest] New emulator found: emulator-5554
[2010-05-29 09:38:18 - ReverseSnakeTest] Waiting for HOME ('android.process.acore') to be launched...
[2010-05-29 09:44:10 - ReverseSnakeTest] HOME is up on device 'emulator-5554'
[2010-05-29 09:44:10 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 09:44:10 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 09:45:52 - ReverseSnakeTest] Success!
[2010-05-29 09:45:53 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 09:45:53 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 09:45:53 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 09:46:21 - ReverseSnake] Success!
[2010-05-29 09:46:21 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 09:46:21 - ReverseSnakeTest] Done!
[2010-05-29 09:52:38 - ReverseSnakeTest] ------------------------------
[2010-05-29 09:52:38 - ReverseSnakeTest] Android Launch!
[2010-05-29 09:52:38 - ReverseSnakeTest] adb is running normally.
[2010-05-29 09:52:38 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 09:52:38 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 09:52:38 - ReverseSnakeTest] Performing sync
[2010-05-29 09:52:38 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 09:52:52 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 09:52:52 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 09:53:06 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 09:53:06 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 09:53:06 - ReverseSnakeTest] Done!
[2010-05-29 11:07:52 - ReverseSnakeTest] ------------------------------
[2010-05-29 11:07:52 - ReverseSnakeTest] Android Launch!
[2010-05-29 11:07:52 - ReverseSnakeTest] adb is running normally.
[2010-05-29 11:07:52 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 11:07:52 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 11:07:52 - ReverseSnakeTest] Performing sync
[2010-05-29 11:07:52 - ReverseSnakeTest] Automatic Target Mode: launching new emulator with compatible AVD 'my_avd'
[2010-05-29 11:07:52 - ReverseSnakeTest] Launching a new emulator with Virtual Device 'my_avd'
[2010-05-29 11:08:00 - ReverseSnakeTest] New emulator found: emulator-5554
[2010-05-29 11:08:00 - ReverseSnakeTest] Waiting for HOME ('android.process.acore') to be launched...
[2010-05-29 11:26:03 - ReverseSnakeTest] HOME is up on device 'emulator-5554'
[2010-05-29 11:26:03 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 11:26:06 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 11:27:23 - ReverseSnakeTest] Success!
[2010-05-29 11:27:25 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 11:27:25 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 11:27:26 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 11:28:32 - ReverseSnake] Success!
[2010-05-29 11:28:34 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 11:28:34 - ReverseSnakeTest] Done!
[2010-05-29 15:31:21 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:31:21 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:31:21 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:31:21 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:31:21 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:31:21 - ReverseSnakeTest] Performing sync
[2010-05-29 15:31:22 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 15:32:30 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 15:32:30 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:32:57 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 15:32:57 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:32:57 - ReverseSnakeTest] Done!
[2010-05-29 15:33:14 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:33:14 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:33:14 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:33:14 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:33:14 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:33:14 - ReverseSnakeTest] Performing sync
[2010-05-29 15:33:14 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 15:33:42 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 15:33:42 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:34:02 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 15:34:02 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:34:02 - ReverseSnakeTest] Done!
[2010-05-29 15:34:28 - Emulator] emulator: emulator window was out of view and was recentred
[2010-05-29 15:34:28 - Emulator] emulator: ERROR: unexpected qemud char. channel close
[2010-05-29 15:34:32 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:34:32 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:34:32 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:34:32 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:34:32 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:34:32 - ReverseSnakeTest] Performing sync
[2010-05-29 15:34:32 - ReverseSnakeTest] Automatic Target Mode: launching new emulator with compatible AVD 'my_avd'
[2010-05-29 15:34:32 - ReverseSnakeTest] Launching a new emulator with Virtual Device 'my_avd'
[2010-05-29 15:34:51 - ReverseSnakeTest] New emulator found: emulator-5554
[2010-05-29 15:34:51 - ReverseSnakeTest] Waiting for HOME ('android.process.acore') to be launched...
[2010-05-29 15:38:34 - ReverseSnakeTest] HOME is up on device 'emulator-5554'
[2010-05-29 15:38:34 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 15:38:35 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 15:40:12 - ReverseSnakeTest] Success!
[2010-05-29 15:40:12 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:40:12 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 15:40:13 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 15:40:50 - ReverseSnake] Success!
[2010-05-29 15:40:51 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:40:51 - ReverseSnakeTest] Done!
[2010-05-29 15:51:14 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:51:14 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:51:14 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:51:14 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:51:14 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:51:14 - ReverseSnakeTest] Performing sync
[2010-05-29 15:51:14 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 15:51:28 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 15:51:28 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:51:40 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 15:51:40 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:51:40 - ReverseSnakeTest] Done!
[2010-05-29 15:51:50 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:51:50 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:51:50 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:51:50 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:51:50 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:51:50 - ReverseSnakeTest] Performing sync
[2010-05-29 15:51:50 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 15:52:08 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 15:52:08 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:52:22 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 15:52:22 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:52:22 - ReverseSnakeTest] Done!
[2010-05-29 15:55:42 - ReverseSnakeTest] ------------------------------
[2010-05-29 15:55:42 - ReverseSnakeTest] Android Launch!
[2010-05-29 15:55:42 - ReverseSnakeTest] adb is running normally.
[2010-05-29 15:55:42 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 15:55:42 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 15:55:42 - ReverseSnakeTest] Performing sync
[2010-05-29 15:55:42 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 15:55:55 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 15:55:55 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 15:56:09 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 15:56:09 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 15:56:09 - ReverseSnakeTest] Done!
[2010-05-29 16:01:02 - ReverseSnakeTest] ------------------------------
[2010-05-29 16:01:02 - ReverseSnakeTest] Android Launch!
[2010-05-29 16:01:02 - ReverseSnakeTest] adb is running normally.
[2010-05-29 16:01:02 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 16:01:02 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 16:01:02 - ReverseSnakeTest] Performing sync
[2010-05-29 16:01:02 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 16:01:18 - ReverseSnakeTest] Application already deployed. No need to reinstall.
[2010-05-29 16:01:18 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 16:01:31 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 16:01:31 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 16:01:31 - ReverseSnakeTest] Done!
[2010-05-29 16:18:23 - ReverseSnakeTest] ------------------------------
[2010-05-29 16:18:23 - ReverseSnakeTest] Android Launch!
[2010-05-29 16:18:23 - ReverseSnakeTest] adb is running normally.
[2010-05-29 16:18:23 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 16:18:23 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 16:18:23 - ReverseSnakeTest] Performing sync
[2010-05-29 16:18:23 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 16:18:23 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 16:18:24 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 16:18:52 - ReverseSnakeTest] Success!
[2010-05-29 16:18:53 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 16:19:33 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 16:19:33 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 16:19:33 - ReverseSnakeTest] Done!
[2010-05-29 16:23:26 - ReverseSnakeTest] ------------------------------
[2010-05-29 16:23:26 - ReverseSnakeTest] Android Launch!
[2010-05-29 16:23:26 - ReverseSnakeTest] adb is running normally.
[2010-05-29 16:23:26 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 16:23:26 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 16:23:26 - ReverseSnakeTest] Performing sync
[2010-05-29 16:23:26 - ReverseSnakeTest] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 16:23:26 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 16:23:26 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 16:23:50 - ReverseSnakeTest] Success!
[2010-05-29 16:23:51 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 16:23:51 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 16:23:53 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 16:24:24 - ReverseSnake] Success!
[2010-05-29 16:24:26 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 16:24:26 - ReverseSnakeTest] Done!
[2010-05-29 16:37:20 - ReverseSnakeTest] ------------------------------
[2010-05-29 16:37:20 - ReverseSnakeTest] Android Launch!
[2010-05-29 16:37:20 - ReverseSnakeTest] adb is running normally.
[2010-05-29 16:37:20 - ReverseSnakeTest] No Launcher activity found!
[2010-05-29 16:37:20 - ReverseSnakeTest] The launch will only sync the application package on the device!
[2010-05-29 16:37:20 - ReverseSnakeTest] Performing sync
[2010-05-29 16:37:20 - ReverseSnakeTest] Automatic Target Mode: launching new emulator with compatible AVD 'my_avd'
[2010-05-29 16:37:20 - ReverseSnakeTest] Launching a new emulator with Virtual Device 'my_avd'
[2010-05-29 16:37:26 - ReverseSnakeTest] New emulator found: emulator-5554
[2010-05-29 16:37:26 - ReverseSnakeTest] Waiting for HOME ('android.process.acore') to be launched...
[2010-05-29 16:42:12 - ReverseSnakeTest] HOME is up on device 'emulator-5554'
[2010-05-29 16:42:12 - ReverseSnakeTest] Uploading ReverseSnakeTest.apk onto device 'emulator-5554'
[2010-05-29 16:42:12 - ReverseSnakeTest] Installing ReverseSnakeTest.apk...
[2010-05-29 16:44:15 - ReverseSnakeTest] Success!
[2010-05-29 16:44:15 - ReverseSnakeTest] Project dependency found, installing: ReverseSnake
[2010-05-29 16:44:15 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 16:44:16 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 16:45:37 - ReverseSnake] Success!
[2010-05-29 16:45:38 - ReverseSnake] org.eclipse.core.internal.resources.ResourceException: Resource '/ReverseSnake' does not exist.
[2010-05-29 16:45:38 - ReverseSnakeTest] \ReverseSnakeTest\bin\ReverseSnakeTest.apk installed on device
[2010-05-29 16:45:38 - ReverseSnakeTest] Done!
[2010-05-29 16:56:02 - ReverseSnake] R.java was modified manually! Reverting to generated version!
[2010-05-29 17:08:16 - ReverseSnake] Error in an XML file: aborting build.
[2010-05-29 17:08:58 - ReverseSnake] ------------------------------
[2010-05-29 17:08:58 - ReverseSnake] Android Launch!
[2010-05-29 17:08:58 - ReverseSnake] adb is running normally.
[2010-05-29 17:08:58 - ReverseSnake] Performing shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake activity launch
[2010-05-29 17:08:58 - ReverseSnake] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 17:08:58 - ReverseSnake] Uploading ReverseSnake.apk onto device 'emulator-5554'
[2010-05-29 17:08:58 - ReverseSnake] Installing ReverseSnake.apk...
[2010-05-29 17:09:30 - ReverseSnake] Success!
[2010-05-29 17:09:31 - ReverseSnake] Starting activity shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake on device
[2010-05-29 17:09:45 - ReverseSnake] ActivityManager: DDM dispatch reg wait timeout
[2010-05-29 17:09:45 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 52454151: no handler defined
[2010-05-29 17:09:45 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 48454c4f: no handler defined
[2010-05-29 17:09:45 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 46454154: no handler defined
[2010-05-29 17:09:45 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 4d505251: no handler defined
[2010-05-29 17:09:53 - ReverseSnake] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=shankar.AndroidMaterial.eclipse.ReverseSnake/.ReverseSnake }
[2010-05-29 21:09:39 - ReverseSnake] ------------------------------
[2010-05-29 21:09:39 - ReverseSnake] Android Launch!
[2010-05-29 21:09:39 - ReverseSnake] adb is running normally.
[2010-05-29 21:09:39 - ReverseSnake] Performing shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake activity launch
[2010-05-29 21:09:39 - ReverseSnake] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 21:09:54 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 21:09:54 - ReverseSnake] Starting activity shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake on device
[2010-05-29 21:10:02 - ReverseSnake] ActivityManager: DDM dispatch reg wait timeout
[2010-05-29 21:10:02 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 52454151: no handler defined
[2010-05-29 21:10:03 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 48454c4f: no handler defined
[2010-05-29 21:10:03 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 46454154: no handler defined
[2010-05-29 21:10:03 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 4d505251: no handler defined
[2010-05-29 21:10:12 - ReverseSnake] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=shankar.AndroidMaterial.eclipse.ReverseSnake/.ReverseSnake }
[2010-05-29 21:10:18 - ReverseSnake] Attempting to connect debugger to 'shankar.AndroidMaterial.eclipse.ReverseSnake' on port 8630
[2010-05-29 21:17:15 - ReverseSnake] ------------------------------
[2010-05-29 21:17:15 - ReverseSnake] Android Launch!
[2010-05-29 21:17:15 - ReverseSnake] adb is running normally.
[2010-05-29 21:17:15 - ReverseSnake] Performing shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake activity launch
[2010-05-29 21:17:15 - ReverseSnake] Automatic Target Mode: using existing emulator 'emulator-5554' running compatible AVD 'my_avd'
[2010-05-29 21:17:29 - ReverseSnake] Application already deployed. No need to reinstall.
[2010-05-29 21:17:29 - ReverseSnake] Starting activity shankar.AndroidMaterial.eclipse.ReverseSnake.ReverseSnake on device
[2010-05-29 21:17:36 - ReverseSnake] ActivityManager: DDM dispatch reg wait timeout
[2010-05-29 21:17:36 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 52454151: no handler defined
[2010-05-29 21:17:36 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 48454c4f: no handler defined
[2010-05-29 21:17:36 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 46454154: no handler defined
[2010-05-29 21:17:36 - ReverseSnake] ActivityManager: Can't dispatch DDM chunk 4d505251: no handler defined
[2010-05-29 21:17:43 - ReverseSnake] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=shankar.AndroidMaterial.eclipse.ReverseSnake/.ReverseSnake }
[2010-05-29 21:17:43 - ReverseSnake] ActivityManager: Warning: Activity not started, its current task has been brought to the front
