twister6
Android Expert
This is a review of Aukey Quick Charge 2.0 (Qualcomm certified) wall charger. http://www.amazon.com/dp/B00QEX83LA/ ($16.99), product page: http://www.aukey.com/product/pau28-qualcomm-quick-charge-usb-adapter
This is going to be a quick review since we are talking about a wall charger, though it's not an ordinary one but rather featuring Qualcomm Quick Charge 2.0 technology implemented in our Galaxy Note 4 as part of an adaptive fast charging. I see more of these wall chargers starting to pop up, but want to be sure you guys/gals don't fall for ebay scams and rather go with a trusted brand names that has been around for awhile and offer a solid warranty and tech support. The idea of Quick Charger 2.0 tech is to implement a higher voltage adaptive charging (at 9V or 12V instead of typical 5V) to accelerate charging of your smartphone battery. A number of new phones and tablets can take advantage of this adaptive fast charging already, while this product is also backward compatible with older phones to charge at 5V. Furthermore, you have to keep in mind that max current rating doesn't mean that your older phone will be drawing more current, it shouldn't sink more than it's maximum current rating. Therefore this particular charger from Aukey is universal to work with newer phones and also backward compatible with older ones, even those that can't take advantage of 2A charging.
The product itself arrived in a small environmentally safe box with just a charger and user manual. It would have been good if they would include usb to micro-usb cable, but I guess Aukey assumed that we already have plenty of those laying around. Just please keep in mind, for a higher voltage/current fast charging make sure to use a higher quality thicker usb cables. Thinner "data" usb cable are not intended for high current, and as a matter of fact can current-limit charge resulting in overheating.
Overall, this Aukey Quick Charger 2.0 performed exactly the same as Samsung Galaxy Note 4 original fast charger, which makes it a great replacement or a second set to keep in your office or when traveling. The build quality is good, feels solid in my hand, didn't overheat - no complaints here!
Here are the pictures.
Aukey Quick Charger 2.0 between a regular and adaptive fast charge (Note 4) Samsung chargers
With a regular Sammy charger
With Note 4 Sammy fast charger
With Aukey fast charger
