twister6
Android Expert
This is a review of the latest Fidue A33, A65, and A73 IEM models. http://www.fidue.com/index_cn.asp
No matter if it's their budget or flagship model, one thing you can always count on with Fidue is a very unique design and presentation that makes them stand out from the crowd. Founded by a well known Chinese earphones designer Benny Tan, the name of the company is actually an acronym for: F (Fidelity, Natural original voice of high fidelity), I (Inspired, The resonance of soul), D (Durable, Long-lived quality), U (Unique, the unique design), and E (Enjoyable, enjoy happily). Though the level of "Fidelity" will vary from model to model, everything else is applicable to all of their headphones. But at the end of the day eye-candy presentation is not enough, and we base our final decision on a sound quality to determine which model will suite our needs better. I hope my review will help you with this decision if you find yourself at the crossroad with these new Fidue IEMs.
Starting with their more basic A33 model ($29.90, http://penonaudio.com/FIDUE-A33), despite its lower price and a single 8mm dynamic driver design, you still get a nice and clear packaging with a display presentation of headphones peaking through the front "window". This packaging is complete with a signature green background and a design/functionality description on the front and company background info on the back. A comprehensive Spec is listed on the back as well.
With this being a "basic" model, don't expect too many accessories. You get only 3 pairs of S/M/L eartips, but I do have to mention these are not some cheap disposable eartips but rather a step up with a better quality and a nicer springy cap. I didn't even have to do tip rolling going through my eartip collection, picking the Large one worked for me without a problem.
A33 - Unboxing and accessories.
The design A33 is not necessary premium, but it looks durable enough. Starting with a headphone plug, you have right angle connector and molded rubbery housing which goes into a flat "noodle" style cable. Going up, y-splitter is also a small molded piece. Though there was no strain relief around the plug or splitter, flat rubber shielding of the wire should give some level of bend protection at the joints. Right side of the cable going to earpiece has in-line remote with a single multi-function button and a mic opening.
Remote is plastic and small enough to match the overall theme of the design. The button on the remote has the same matching golden color as earpieces. Remote itself has a basic single click Play/Pause/Call functionality and double-click to skip to the next track. Obviously, this is a universal remote without volume control since iOS and Android differ in this respect. Though I don't have access to super noisy environment, testing phone call quality yielded an ok results, and having remote/mic closer to my face helped with voice pickup. Also, typical for flat cable design, microphonics effect is present when cable rubs against your cloth.
Moving up to cylindrical lightweight aluminum earpieces, cable attaches through an interesting molded piece which goes around the middle of the earpiece and extends to form a strain relief. In there, you can find a stamped L/R marking, but they are very hard to see. Luckily, I was using in-line remote located on the right side as my guidance to determine L/R earpiece. Earpieces themselves have a traditional cylindrical design, golden color finish, a matching golden wire mesh covering a nozzle, and a pinhole vent opening on the back.
A33 - Design details and fitment.
When it comes to sound quality, I gotta be honest I wasn't too crazy about it at first. A33 has L-shape sound dominated by enhanced sub-/mid-bass and with rolled off treble. You get a serious boost of low end which makes sound somewhat muddy and also bleeds into lower mids. Mids are warm and thick, a little pushed back behind low end boost, and treble doesn't extend too far. It almost feels like someone applied an EQ to filter out all the upper frequencies. But luckily you can restore the sound by trimming down bass around 31Hz and 63Hz and boosting highs around 8kHz and 16kHz. It responds really well to EQ adjustment and with a right tweaking you can actually shape a sound to a rather decent sig.
I found soundstage to be below average in width/depth. With the original tuning the separation and layering wasn't even worth mentioning since everything sounded like a hot mess, but with EQ tweaking I was able to make a serious progress. It paired up well with my Note 4 where with a default stock audio player I was able to use Samsung internal effects matrix to tune it for vocal performance which yielded quite a nice sound signature. My advice, if you really like the look of these IEMs and want something durable for everyday use, these my suite your needs as long as you willing to adjust the sound to shape it to your liking.
Moving on to A65 ($65, http://penonaudio.com/FIDUE-A65), now we are getting into a higher quality offering from Fidue. Though still with 8mm dynamic driver, this one is actually a Titanium driver which typically offers a more controlled and tighter low end and clear mids and treble. Keeping up with a more premium quality in comparison to A33, A65 packaging has a sturdier carton box with a foam/felt cutout tray that houses IEMs and eartips. You are still getting a traditional "F" checker graphics pattern and a section with a green background going over design details. Of course, you should expect a detailed Spec on the back as well.
With accessories, in addition to 3 pairs of the same S/M/L silica gel eartips, you also get a pair of double-flange tips, a shirt clip, and a storage drawstring pouch. Storage pouch has actually a nice to the touch finish. In theory, these are not necessary a premium accessories, but it's nice how Fidue distinguishes A65 model from A33.
A65 - Unboxing and accessories.
While accessories might not be necessary of a top premium quality, the design makes up for it and then some! Looking at the straight slim gold plated headphone plug you will recognize finish of Pistons headphone plugs - a very similar design with a laser etched fine grooves and a nice strain relief. Cable has a semi transparent rubbery shielding with a grippy touch and bi-color wires you can see through this shielding. The wires are actually upgraded 7N purity OFC which should definitely improve sound quality. There is a little bit of microphonics effect, but not too bad. Moving up to a y-splitter, it has a matching slim cylindrical shape with a same finish as headphone plug and a nice strain relief on both sides. The same for the wire going to the right earpiece with a cool in-line remote with mic.
And again, the in-line remote has a matching cylindrical design and the same fine-groove etched finish, including the same strain relief on both sides. What makes this remote even more special is a discrete multi-function button with a single click function of Play/Pause/Call and double-click function to skip a track. Just like A33, this is a universal in-line remote without volume control. Phone call quality was good, and my voice was heard loud and clear thanks to remote/mic being closer to the face.
Moving up to the shell - this is where A65 really stands up above competition. The main body of the shell is made out of what appears to be a solid copper, while the back of the shell has thicker stainless steel plate with a cool "F" logo etching. The nozzle part of A65 also seems to be either aluminum or some alloy. You do feel a little bit of extra weight when holding them in your hands, but they do sit comfortably in my ears with a wire down. Furthermore, there is a pinhole vent at the bottom of the nozzle and another vent on the back under the metal plate facing the wire attachment. Speaking of that attachment, it has a nice strain relief and the same problem with L/R marking which is hard to see. But Fidue also added an ID bump on Right side of strain relief so you can distinguish L/R side in the dark just by sliding a finger. If everything else fails, in-line remote/mic is on the right.
