Review of iHave NFC/BT4.0 phone headset w/lots of pics!!!
twister6
Android Expert
This is a review of iHave NFC BT4.0 headset. IHAVE Comi M NFC Function Bluetooth 4.0 Headphone for iPhone iPad Samsung Sony HTC Etc. - Bluetooth Headsets
Every time I think these single on-ear headsets are the thing of the past, I ran into more people on the street or in the cars using it. That is why I continue reviewing these wireless bluetooth headset and constantly look for something new and innovative. Typically, they all have a similar functionality, only with different design looks. But some do stand out by offering the latest low power BT4.0 or support of A2DP and HFP profiles to stream your audio from the phone. More expensive models from brand names go into other features but those will cost you over $100. While I was researching for the next review, I came across this new Chinese brand, iHave, which is currently being sold on Cell Phone Accessories Wholesale Online Store – TVC-Mall.com as one of their official distributors. When I started to read the spec, I thought to myself that it's almost too good to be true, so obviously I requested a review sample to test it myself so I can share my review with you. Here is what I found.
This iHave headset arrived in a very professional package with a nice clear display presentation, though I wasn't able to read anything on the back since it was in Chinese. Luckily, they included a set of detailed instructions in English, although the operation is very intuitive so you don't even need instructions. In addition to headset, the accessories included 3 sets of eartips including 2 with stabilizer, behind the ear hook, and a magnetic charger. Though there is no direct micro-usb connection to headset, to keep a design slim, the included magnetic charger is something you will find only in high end expensive headset. For whose who use this type of headset, you probably aware that plugging/unplugging of micro-usb connector puts a lot of wear'n'tear on the headset. Here, it's a zero effort to bring it close for an attachment and plugging full usb connector into your wall charger or computer. It fully charges in less than an hour, provides almost 4hr of talk time, and about 5 days of standby time.
Now, about the headset design. It's very thin and lightweight, with an elegant surface texture. It definitely doesn't look or feel cheap, though made out of plastic. Conveniently located at the corner of back edge, there is a multifunction button, wide enough for easy location. At the bottom edge you have a physical on/off switch which is a great option to eliminate any second guessing if you headset is on or off. At the top edge, you have volume up/down rocker which also supports playback control. YES, you can skip next/prev track when streaming the music by holding down volume buttons, while multifunction button works as play/pause. I hardly seen any other headsets of the same type which offer full A2DP1.2 and HFP1.6 support including playback control.
And if that wasn't enough, this headset also support NFC for a fast pair up with your phone. All I had to do is to place it near my Note 2, and it recognized and paired to phone and media audio within seconds without me even lifting a finger. The operation was very robust and worked even with my phone case on. You can pair it up with up to 8 bluetooth devices, and it even supports pair up with 2 devices at the same time. Though I tested the calling in relatively noise free environment (everything sounded crystal clear), it supports CVC6.0 dual mic noise cancellation.
Overall, I was very impressed with a design and a performance of this wireless headset. Pretty much it included every piece of available technology from magnetic charging clip, to NFC and BT4.0 support with the latest A2DP1.2/HFP1.6 protocols, full playback controls when streaming audio media from your phone, and universal compatibility with any bluetooth enabled devices. It also looked really cool. The best part? It only cost $27.89. At that price and with all these features, instead of calling it iHave they should rename it to iMustHave :) This one definitely gets my recommendation!
Here are the pictures.
