Help Ring multiple times for text messages
Hello, I'm new to Android as I just got the Nexus One. On my previous flipphone, when I get a text message, it will make the ringtone sound a 4 or 5 times. My question is how to set android to do multiple rings for texts instead of once?
Also, is there a way to make it sound the notification ringtone for texts only, and not for app alerts, like the weather channel widget?
An app called SMSPopup will give you (configurable) reminder notifications for received texts - don't forget to switch off notifications in the Messaging app if you use SMSPopup otherwise you'll get double notifications per message.
