Ring tones for each contact
If you have the ringtone you want on your ringtone list, go to your contacts and pick the contact you want. Hiot the menu - options button at the bottom mof the screen. Then hit "options" from the pop up menu, then "ringtone". Your ringtone list should appear. Make your choice.
I went to zedge.net and created a ring tone for each of my important contacts. Each ring tone starts with some kind of tone that I set, then speaks the contact's name.
