Ringtone help
Chelle920
Im trying to use a ringtone i downloaded off of myxer.com.
But when i look at switching the ringtone the only ringtones available are the default ones...please help
there is a free app on the market called RingDroid. it allows you to edit your music and turn it into ringtones, notification sounds or alarm sounds. if you already have the ringtone ready, you should only open it and save it as a ringtone, and then it should show in your ringtones list. you can also open your music and save just a section of a track as the ringtone.
check it out here Ringdroid | AndroidApplications.com
i've been using it for some time now and it really does the job well. hope it helps!
