Root [rom] 32/7/12 cm9 primou gsm Beta 3
############ CHANGELOG#####################
Beta 3 31/7/12
Video Recording - only 480p works - 720p crashes camera.
WIFI Tether is fixed
USB Tether is fixed
Beta 2 (netflix edition) 30/7/12
WIFI works
Netflix works
many other fixes
Torch is fixed (unstable)
Wifi tether (should work)
nice one JMZ for the above fixes
Build CM9 BETA 1 23/7/12
USB Storage now works
Audio + Mic has been refixed
ALL Graphics fixed
Camera now previews 100% properly
To overclock you need to use an App eg: Setcpu and so on...currently the setting does not work inside CM9.
Thanks to Technolover for sorting the USB mount and the camera preview and build issue out while I was busy
Build CM9 0.4 19/7/12
Updated incremental, from now on the build will be coming from my tree.
Build CM9 0.3 17/7/12
Using the new build tree (FINALLY)
Introduced a new bug graphical glitches for all, enjoy them while they last!!
ADB works *again*
i will keep 0.2 download up for now untill 0.3 is free of graphical glitches
Build CM9 A.02 (Alpha 2) 15/7/12
Camera works with some artifacts on preview but saves fine
Video Works though it MIGHT not record
Flash for camera and Video works
nice one 1ceb0x for testing and adding a couple of files i overlooked
(we didnt mean to fix camera it just "happened")
I've been away for a few days but it says Beta 1.1 now on your xda post. However, the changelog only has Beta 1 details. Just curious if that changelog should read 1.1 or are those updates applicable to Beta 1 only?
I'm just getting eager to try your ROM out :-)
yea i had a test out which i thought worked which was Beta 1.1 instead now i will merge 1.1 into Beta 2 instead :p
so on these roms, do mms and sms work fine? also can someone please post some pics of what things look like? also, what does the messaging system look like? Sense or ICS?
1) MMS works i have had reports that it can be a bit tempermental
2) SMS works
3) im deving this without my phone so it's bricked and if you've seen CM9 once im sure there's no need to post images
4) it's stock CM9 No changes NOTHING
Lloir, great ROM here, so glad there is a true no-Sense ROM for the One V. I've been using it everyday since Beta2 with no issues. Ill update to 3.1 in a bit :-)
Updated the download links, also for bluetooth to work flash the new boot.img (check the downloads up top)
