(Rom)(Alpha) BAMF Paradigm (Port)
  • Thread starter Thread starter techno-update
  • Start date Start date
Status
Not open for further replies.
T
techno-update
Guest
This is a port from a pretty cool rom created by Team BAMF for the Galaxy Nexus, find their original rom here. Be sure to thank them!
Disclaimer
I am not responsible for what you do to you phone, if you mess it up, don't blame me!
Known Issues:
Rotation Problem
ICS camera features
Camcorder
HW Video Codecs
Bluetooth
Please report anything I missed didn't really have much time to test stuff.
Follow Me on Twitter
Download:
Get the download link from my site here!
Like my work? Hit the Thanks Button!
GSM Users:
You need to edit the build.prop located in the system folder. Recommend using winrar
/system/build.prop
Once there, you will open the file and edit it using a word processing program of you choice. Notepad is fine.
Use search/find button till you locate something that says this Default network type. # 4 => CDMA
From there change the 4 to a 3.
Then next to it you will see this ro.telephony.default_network=4, change it to 3.
This should work, if it doesn't please tell me so I can try and help!
Thanks to:
Hashcode, made the CM9 rom for Droid 3.
BAMF Team-
Erishasnobatter
Ihtfp68
Adrynalyne
ThatDudeButch
Their Site
Status
