Arrow OS 13.0 Custom Rom
And Optional Dual Boot Setup
--PLEASE NOTE THIS IS A WORK IN PROGRESS development happening daily--
Device: Moto G7 Plus
CodeName: lake
Model: XT1965
Android Version: 13
Build Type: VANILLA / GAPPS
A-Team Version: 0.03
Rom Built By: PizzaG
DualBoot-Mod By: PizzaG & LgPWNd
Contribution & Testing By : LgPWNd
*Now Uses A-Team Custom Rom Installer*
-Uses Volume Keys For Selectable Options
-Dual Boot Install Option #project codename Droolboot ™️ ©
-Option To Disable Encryption
-User Selects Gapps Or Vanilla On Install
— Custom Rom Installation —
*WILL WIPE DATA*
-Put Rom .zip On Device External Storage
-Flash & Boot TWRP
-Format Data With Yes Option
-Flash Rom
-Follow Prompts In Installer
-Done!!
— Dual Boot External SD Card Setup —
-Read Included DualBoot-ReadMe.txt
—Release Updates v0.03—
Installer supports Dual Boot now, attempt to fix hotspot, Patched external SD Card DualBoot error
—Credits:
ArrowOS team for Arrow
John Wu for magisk
A-Team: PizzaG and LgPWNd
...and many others i can't begin to name here =]
#Our delicious Roms and Kits Downloads Main Channel :
#Our Main discussion group where we discuss and test out the latest things A-Team in Real-Time
#This Is where to go if you want help with this or any other A-Team project.
------------------------ WHAT'S THIS ? -----------------
This Is pretty neat We have abused the dynamic update system to bring you a Dual Boot solution.
We are using slot a for our main ROM and slot b for our secondary, the two slots shared /userdata partition, but thanks to
some nice maneuvering in the secondary roms fstab we now use mmcblk1p1 as userdata
that gives us userdata on our sdcard, for this to work you must first prepair the sdcard by making 2 partitions.
1 exfat for the " Sd Card " partition and one ext4 for the new "userdata"
anyway this allows both ROMs to co-exist on the same device and use different slots.
We also have several other roms and kits for this device come by and check it out, all are invited
If you show-up at our Tg Group to grab this or other ROM's:
Please keep your language and your posts there appropriate for general audiences that may include young people.
Thanks For Reading
LgPWNd
A-Team Digital Solutions
CodeName: lake
Model: XT1965
Android Version: 13
*WILL WIPE DATA*
-Flash & Boot TWRP
-Flash Rom
-Done!!
—Credits:
John Wu for magisk
Thanks For Reading
LgPWNd
