[Rom] CDMA Droid Razr | Bionx Nx 2.0.5 | Adreno HD | Beats Bravia | FINAL
Status
Not open for further replies.
Biotic
Android Expert
Bionx Rom Series
Nx 2.0.5
By: Biotic
CDMA Droid Razr/Maxx
The Final Installation of Nx is Finally here!
Bionx Development Home
Bionx Rom Features
*Heavily Modified Framework and Framework.jar
-AOSP Styled Lockscreen
-AOSP Coded Integrated for smoother processing
-Navigation Bar Build.Prop Toggle Integrated
-Modified ERI Settings
-Screen Power Savings
-Network Optimization Tweak
-Charge Indicator Disabled
-Battery Savings Tweaks
-Optimized System To Save System Space
-Deleted Unwanted/Uneeded Code
*Heavily Modified Services.jar
-CPU Processing Tweak
-Services Per Limit Tweak
-Battery Optimized
-Super Charged
*Heavily Modified AndroidPolicy.jar
-AOSP Lockscreen Code Integrated
-Experimental Reboot Menu Code Integrated
-Optimized For Bionx System
*Heavily Modified Systemui
-Remasted Toggle Widgets
-ERI Modification
-Jellybean Like Style (My version)
-Center Clock
-Bottom Toggles
-Date Moved To Notification Button Bar
*Applications
-Modified Android Settings
-AOSP Browser (Built from source)
-Transparent Cyanogen MMS (Built from source)
-Sony Xperia Walkman Player (Beats Bravia HD Audio System Included)
-Beats Audio (Bravia Mod from Sony Devices Ported)
-Inverted Gapps from AOKP Team
-Inverted Google Play (Not current version yet)
-Super SU Integrated
-Smart Actions Included
-Sony Xperia Keyboard
-Mobile Hotspot (Free)
-Google Now (ICS version optimized for Nx)
-Xperia Favorite Contacts
-Modded Droid X LWP (Modded By Me)
-Modded PhaseBeam LWP
-Bionx Wallpapers (Grab from the Google Play Store by Searching Biotic)
*Bionx Application
-Remastered with ICS Layer
-AOKP CPU Scripter
-Nx CPU Overclocker
-CPU Sleeper
-Spare Parts
-Launcher Manager
-Beats
-Manage Downloads
-MIUI File Manager
NEW -Batch APK Installer
NEW -Security Gaurd
-Rom Changelog Viewer
-Bionx Rom System Information
*System
-HTC Sense Sky Blue Themed
-Droid DNA Bootanimation/sound
-Optimized System Sounds
-HD Adreno Driven (HD Display)
-Super Charge Optional
-Honeycomb Based Icons
-Beats Bravia HD Sound
-Tweaked Bin/Xbin
-Perimission Fix on Boot
-CPU Run-time Tweak
-Battery Tweaks
-Build.Prop Nav Bar Tweak (Enable/Disable Nav Bar via build.prop editor)
-Tweaked APN
-Tweaked Busybox
-Smart Start Boot (Clean unwanted data)
-Init.d Support
-System Reformatted For The Better
Bugs
-Xperia Visualizer will force close on click. Fix by reinstalling app from system
-Beats audio is iffy...
-4g settings in Android Settings force closes on click, blank activity.
-Battery icon may jump from 10% to 5% fix by charging device too 100% via safestrap, clear caches and reboot.
"How do I enable Navigation Buttons?"
Easy peasy in Nx 2.0! Download a build. prop editor and navigate in the build. prop to the section where it says Nav Button Toggle. You should see a line of code similar to this...
qemu.hw.mainkeys.=1
1=disable 0=enable
changes values, save and reboot!
"Can I upgrade my Nx 1.6 to 2.0?"
Yes however i recommend a clean install so you can take advantage of a clean new system, bugs may generate if you do a system upgrade.
"Do i need to update my safestrap to 3.0+?"
Yes! no ifs ans or buts
"Are there any themes or mods available for Nx 2.0?"
Not from my end, all themes and mods are up to the community.
"Wheres Navi?"
Still in development and needing developers to help finish it.
"Will Nx have a sequel to jellybean?"
Eventually, times are busy these days
READ ME!!!
"How do I use the Bionx Dashboard??"
The Bionx Dashboard is the Bionx Rom's Framework basically. This app monitors, stabilizes, and powers the rom from the heart of the OS. When the user clicks on the Bionx Dashboard app, a splash screen will appear and load up rom information, here the user can press the MENU button on their device and this will take the user to the toolbox. In here, users will be presented with an ICS Icon based Preference Screen. (Just like the android settings) The 3 blank force close activities have been fixed and removed. This toolkit is unlike any other for a stock rom and will help the user power and control their rom.
Definitely remove the 4.2 camera and gallery cuz it is freezing my phone like no tomorrow. Plus it is very laggy and isn't even fully functional. Otherwise, so far it is pretty smooth :)
Yes, Camera issue freezes up phone and reboot is necessary to get back to speed..
Rom looks nice and is very smooth..
To prevent the gallery from force closing or the camera doing the same. grab a file manager and rename any folder containing pictures from DCIM to anything else in your memory.
I agreed the same but people pushed for the 4.2 camera so id let the users see for themselves
I know what you mean. Personally though I prefer full functionality and full stability. That's just me. The 4.2 camera doesn't even have working photosphere and its a hassle to me personally
I might have broke something while modifying the settings manifest so il have to take a look later.
Things on my checklist
-Remove 4.2 camera and get working camera and gallery back
-Remove CPU Sleeper (Any objections, speak now)
-Fix Android Settings Sync
-Integrate Nx Papers and fix stretch bug
-Add Bionx Tips
-Nx Scripts (Various system commands)
-Clean up any mistakes or code mismatches
-Update Droid X LWP (Make it more appealing)
-Attempt Developer Features (Port features from other roms i wish to have in Nx, risky)
I had installed safestrap 2.11 so that i could install bionx 1.6. I uninstalled 2.11 and installed 3.05 so i could install 2.0.2. When I install 3.05 and try to boot to the stock rom, which should be 1.6 mind you. It wouldn't boot to it. Just stuck in bootloop. So I installed 2.0.2 and it worked. Went back to safestrap and tried booting back to stock rom and boot loop again. So I decide to do a factory reset on the stock rom and it takes me all the way back to the original rom that came with the phone. How would that be possible after I had already installed 1.6 over top of it. I think I will just run stock for now until you get all the bugs fixed on 2 :(. But it is still weird that a factory reset took me back to stock rom.
You never installed over stock or wiped the stock rom. Safestrap creates partitions on hidden memory on your razr to install roms on. hence the locked bootloader... Reason we do this is so that if we needed the stock firmware for anything, we have it and were technically not harming the device nor rooting it ;)
Ok so i found the bug in the android settings so il make a patch soon to flash to fix it. I accidently disabled the actionbar which is needed to navigate toggles.
Created a 2.0.4 patch today, hopefully it cures a few bug problems. I will release it as soon as I know its doing its job correctly.
Fixed Android Settings
Updated Bionx Application
Updated Build.prop
Updated Changelog
Removed Android 4.2 camera and swapped back to Blur Camera
Removed CPU Sleeper
Added Nav Script "Enable and Disable Nav buttons via Terminal"
In or to port Labled Stock firmwarw, your gonna need a damn good kernel which i am not good at lol plus dont own any samaung devices of my own
Status
