Here I found on a Spain forum two custom roms.
I will explain how to install them and install the custom recovery.
NOT THAT I'M NOT THE AUTOR OF THIS ROMS AND I DO NOT TAKE RESPONSE FOR THE DAMAGE OF YOUR DEVICES
First you need this files:
1) Drivers Huawei (adb drivers) Multiupload.com - upload your files to multiple file hosting sites!
2) Custom CM Recovery Multiupload.com - upload your files to multiple file hosting sites!
1-a)Install the adb drivers for your Huawei (JUST FOLLOW THE STEPS)
2-b)Put your Huawei in fastboot ( Volume down+Power for 10sec)
3-c)Extract Recovery from .rar and run instalador.bat
4-d) Plug your device in fastboot mode to the PC and follow on screen instructions
After the Recovery flash you will reboot in Recovery DO A BACKUP OF YOUR ROM
NOW THE ROMS
Both Roms have OC kernels with speeds of 780MHz for ZAD and 729 for CM7, and a lot of programs were deleted for faster response, but both are GOOD and stable. I have tried it both.
CyanogenMod 7.2
INSTALLATION
Download the Rom
1. Download and put the zip in root of SD card
2. Reboot in recovery (volume up+power 10 sec)
3. Wipe/Clear cache/clear dalvik
4. Install custom zip/ select CM7
5. After install reboot your device
ZaD!!RoM V 1.5
INSTALLATION
4. Install custom zip/ select ZAD
WELL THIS IS IT!!
FOR ANY QUESTION PLEASE FELL FREE TO ASK OR LOOK ROMs y desarrollo Huawei U8650 - HTCMania
NOW THE ROMS
CyanogenMod 7.2
INSTALLATION
Download the Rom
ZaD!!RoM V 1.5
INSTALLATION
WELL THIS IS IT!!
