Lokifish
Standard, you brick your phone it ain't my fault disclaimer..
mostly Universal DeBlur-DeBloat Live ROM Conversion v1.0.8
for
Most Stock/Locked/Rooted Android MotoBlur phones
If you are afraid to unlock or bootstrap but want better performance from your Blurred phone then this is for you!
There's something to be said for Moto's consistency with regards to Blur. Many current Blur APK's retain the same name and levels of integration across multiple devices. What this translates into is that a universal script with subsections for device/carrier specific files that can be used to deBlur the Android Moto line. So without further chatter, here's the "Something Special" I've been working on for ALL you locked Blurred Phone users.
What this script does;
Removes many elements of MotoBlur (see list below)
Removes carrier bloat (currently major US carriers only)
Moves removed apps to Removed_Apps folder
Replaces BlurHome with ADW
Duplicates the Blur look with preconfigured ADW backup files
Frees up about 50MB of space in /system/app
Free up about 60MB of RAM
Replaces the stock build.prop with a tuned build.prop (currently Photon and Electrify only)
Add Blur look toggles (Currently only available for Bionic (ALPHA), Photon and GSM RAZR)
Retains already installed apps and user info (I still suggest you back up your stuff)
build.prop Tweaks vs Stock;
Dalvik increased
Max events increased
3G tweaks
Ring delay tweaks
Proximity on call tweaks
WiFi scan tweaks
Deep Sleep enabled
Proxies zeroed out
Camera/camcorder tweaks
HW acceleration enable
Stagefright tweaks
*What Blur Widgets you loose;
Toggle Widgets (4G Scan is retained and once we have notification toggles for odex builds you won't miss these)
Bookmarks Widget
Calendar Widget (broken)
Quick Contacts Widget
Date and Time Widget
Messages Widget
News Widget
Pictureframe Plus Widget
Social Location Widget
Social Networking Widget
Social Status Widget
Weather Widget
World Clock Widget
*most of these widgets tend to go unused or are duplicated by apps and launchers like Launcher Pro, Facebook, Twitter and the like
ATTENTION Atrix2 Users
There is currently an issue with the Atrix2, ROM Toolbox and the script. Do not use the script unless you want to help troubleshoot it
Officially Supported Phones/Carriers
Requires custom build.prop or notification toggles to make this list.
Unofficial & Unverified Phones
The script works on a ton of MotoBlur phones not on the "Official" list so give it a try and let us know!!!
Instructions:
Downloads:
Right Here
Blur Removed List:
Carrier Bloat Removed List
When posting, please state model of phone and carrier.
Credits:
Notification toggles- Nottach, Rangerbry, pgriffinsc, DroidJunk, dima_sk8er, j4velin
Fix permissions script- JRummy16 (I got lazy)
Electrify and RAZR files- onslaught86
for
Dalvik increased
3G tweaks
Ring delay tweaks
WiFi scan tweaks
Deep Sleep enabled
Proxies zeroed out
Stagefright tweaks
Bookmarks Widget
Messages Widget
News Widget
Weather Widget
World Clock Widget
Code:
Toggles and build.prop;
Atrix
Bionic
Droid X2
Sprint Photon
USCellular Electrify
Toggles Only;
GSM RAZR
Custom build.prop Only;
Charm no toggles
Sprint XPRT no toggles
Instructions:
- Root you phone
- Backup your apps and factory reset your phone (this reduces the chance of a soft brick)
- Copy the "1deblur_lite" folder to internal storage (or sdcard if you do not have internal storage, a.k.a /mnt/sdcard)
- Using the stock file browser go to the "1deblur_lite" folder and install RomToolbox
- Open RomToolbox/Root Browser and go to the /sdcard/1deblur_lite and open the folder for your device (if your device is not listed then open the "Generic" folder)
- Select lite_deblur.sh
- In the popup menu select "Run"
- Ignore all the "Force Close" errors
- Wait til you see "script was run successfully" in the background then pull battery and boot your phone. Pulling the battery before this will require you to SBF to stock
- In ADW Launcher settings select "Backup and Restore" and restore both setting and configuration
- Enjoy your deblurred and tuned phone
Downloads:
Right Here
Blur Removed List:
Code:
AdService.apk
AdService.odex
BlurHome.apk (All phones using this version of Blur)
BlurHome.odex
BlurHome2.apk (All phones using this version of Blur)
BlurHome2.odex
BlurTasks.apk
BlurTasks.odex
BlurUpdater.apk
BlurUpdater.odex
BookmarksWidget.apk
BookmarksWidget.odex
BooksPhone.apk
CalendarSync.apk
CalendarSync.odex
DataCollection.apk
DataCollection.odex
DataCollectorProvider.apk
DataCollectorProvider.odex
DataCollectorService.apk
DataCollectorService.odex
DLNA.apk
DLNA.odex
DlnaSystemService.apk
DlnaSystemService.odex
FriendFeed.apk
FriendFeed.odex
GlobalUnplug.apk
GlobalUnplug.odex
HelpCenter.apk
HelpCenter.odex
MediaSync.apk
MediaSync.odex
MotoPhonePortal.apk
MotoPhonePortal.odex
NewsWidget.apk
NewsWidget.odex
PhotoWidget.apk
PhotoWidget.odex
Protips.apk
Protips.odex
QuickContactWidget.apk
QuickContactWidget.odex
Quickoffice-Motorola.apk
SocialMessaging.apk
SocialMessaging.odex
SocialShare.apk
SocialShare.odex
StatusWidget.apk
StatusWidget.odex
SuggestionsProvider.apk
SuggestionsProvider.odex
SuggestionsRuleCheckerCore.apk
SuggestionsRuleCheckerCore.odex
SuggestionsServiceScheduler.apk
SuggestionsServiceScheduler.odex
Swype.apk
SystemUI.odex (Photon only..for now)
ToggleWidgets.apk
ToggleWidgets.odex
UniversalInbox.apk
UniversalInbox.odex
WeatherWidget.apk
WeatherWidget.odex
WorldClockWidget.apk
WorldClockWidget.odex
W_Installer.apk
Code:
#AT&T Bloat
AT&T Family Maps
ATT-P11_PROD.apk
AT&T Maps
ATT Radio
ATT Hotspots
#Sprint Bloat
SprintMobileWallet
SprintZone
Sprint_Worldwide
Sprint Radio
Sprint Nascar
Sprint Music
Sprint TV
Google Books
Sprint Telenav
Rich Location
#TMobile Bloat
#Verizon Bloat
Amazon Music
Blockbuster
BlurUpdater_VZW.apk
CityID
Kindle
MyVerizon
Skype Mobile Live
VCast
#GSM RAZR
Bejeweled
Credits:
