Rom for Vensmile m9 (s905)?
victor861
Hi, i buyed two android tv box M9 for 20€ in amazon:
Sistema operativo: Android 5.1
Procesador: cuatro núcleos ARM Cortex-A53 CPU de 2,0GHz
Memoria: 1GB de RAM DDR3; 8GB eMMC ROM
Wi-Fi: IEEE 802.11 a/b/g/n inalámbrica a internet
Bluetooth: Bluetooth 4.0
RJ45: Ethernet 10 / 100Mbps
Puertos USB: 3 * USB2.0
Almacenamiento Externo: SD / MMC ayuda de la ranura para tarjeta externa de hasta 64GB SDHC
There is any rom or something?
Hi, Victor...
I understand that English isn't your first language but your question is still too vague to have any hope of getting replies.
Can you elaborate on what it is you're looking for?
Yes, sorry for my english.
I'm looking for a Rom for my Vensmile M9, or maybe an update.
Actually i have some problems (Like bluetooth with Dualshock 4, impossible to pairing) or the Google Play, there are many apps that i can't install.
Thanks a lot.
From what you have told us about your box, at this time of writing (June '16) you have the most up-to-date platform for Android TV right now.
A 'newer' rom or the latest version of Android will probably add to your troubles, NOT fix them!
What Bluetooth devices are you trying to pair and what apps are giving you problems?
Hi, thanks for your reply.
For example, there are a lot of apps of Google play that doesn't appear, in the other box (The same) i dont have that problems, no incompatibilities with apps, nothing, everything ok.
I'm trying to use a Dualshock 4 joystick with the box, but doesnt pair.
Sorry for my english.
