here it is! an unofficial port of eclipse1.3 for the d4! and everything except the front facing camera work. just bypass the setup screen and then add your Google account and your good to go!
[FONT=inherit !important][FONT=inherit ! important]screenshots[/FONT][/FONT]
bluetooth and keyboard work too! this rom runs fast and has no data issues.
_-updated-_
[FONT=inherit !important][FONT=inherit !important]key[/FONT][/FONT] mapping is a ok!
front facing cam is still not workin
Dont install smart actions!!!! Will cause bootloop!
Download:
https://www.dropbox.com/s/dwuqczeze1...pse-v1.3.1.zip
how to install:
install with safestrap 1.09
factory reset then boot it
bypass the setup screen and your good to go
it was originally made by nitroglycerine33 who is the **** lol!
http://www.droidrzr.com/index.php/to...azr-v13-22512/
General Overview
[FONT=inherit !important][FONT=inherit ! important]Gingerbread[/FONT][/FONT] Moto Blur 2.3.6 based cleaned up Moto experience with a few modded goodies.
Deodexed
Zipaligned
Bloat Removed
A lot of blur has been removed
AOSP/CM7 mms
AOSP music
AOSP gallery3D
Eclipse Launcher2
CM7 file manager
AOSP/CM7 Email
AOSP/CM7 alarm clock
AOSP car/desk dock
AOSP news & weather
AOSP calendar
AOSP Sound Recorder
Custom Blur Camera
DSP Manager
Eclipse Parts
Accurate Battery - 1%
CRT Animation ON and OFF
Misc prop edits
Custom Host File
[FONT=inherit !important][FONT=inherit !important]GPS[/FONT][/FONT] [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]config[/FONT][/FONT][/COLOR][/COLOR] changes
Appwidget Picker - boombuler
Download crutch to help with web downloads
Busy Box
init.d support
Eclipse Wallpapers
Custom blue theme throughout
ICS clock widget
ICS Inspired bootanimation
Inverted Contacts/Dialer
Inverted Google Talk2
All Settings menus are inverted
7 pulldown toggles (wireless, [FONT=inherit !important][FONT=inherit !important]bluetooth[/FONT][/FONT], gps, sound/vibrate, auto brightness, data, and rotation)
Native Facebook for android contacts sync
Wake on volume
Extended power controls (reboot,[FONT=inherit !important][FONT=inherit ! important]recovery[/FONT][/FONT], screenshot)
Known Issues:
Do not use the blur "Corporate Sync" in Accounts as this blur feature is disabled. Either add your account by opening the email app or selecting "Corporate." Also, do not attempt to setup a motocast either. It will FC on setup. Use Zumocast instead.
PLEASE NOTE! WHEN RUNNING THROUGH THE INITIAL SETUP. AFTER YOU CLICK ON THE ANDROID GUY PRESS THE HOME KEY AND SKIP SETUP. I STILL NEED TO REMAP THE SETUP SEQUENCE. If YOU GET STUCK ON SETUP TOUCH THE FOUR CORNERS.
Here is some instructions on how to skip setup using the four corner trick: Please Login HERE or Register HERE to see this link!
Download Eclipse v1.3: Please Login HERE or Register HERE to see this link!
For you GO Launcher users out there I have a matching theme you can download from the market: Please Login HERE or Register HERE to see this link!
Extras:
Zumocast Application (MotoCast alternative)
Download: Please Login HERE or Register HERE to see this link!
*install as a normal application
Download Client for [FONT=inherit !important][FONT=inherit ! important]Windows[/FONT][/FONT]; OSX: Please Login HERE or Register HERE to see this link!
Changelog:
v1.3.1 - 4/28/12
Added D4 support
v1.3 - 2/25/12
Fixed 3G/4G icon reporting issues
Fixed speed dial issues
Integrated the Razr camera into the build fixing the camcorder zoom issues
Fixed docking [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]modes[/FONT][/FONT][/COLOR][/COLOR] so the only option is now the aosp deskclock
Added scrolling toggles to the status bar
Fixed some theming issues
Fixed some [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]framework[/FONT][/FONT][/COLOR][/COLOR] resources that were conflicting in the bionic/razr framework
v1.2.1 - 2/22/12
Fixed Netflix playback errors
Set hotspot entitlement value to 0
Removed some remaining blur services
Renamed Eclipse Parts to Eclipse Settings
Moved Eclipse Settings to the top of the Settings list
Added in a few prop tweaks
v1.2 - 2/20/12
Added wake on volume
Added an option to allow 3,5,7 or 9 homescreens with Eclipse Launcher
Added ICS transition animations
Fixed Google Streetview app from not updating in the market
v1.1 - 2/20/12
Added Reboot/Recovery/Screen Capture option in power [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]menu[/FONT][/FONT][/COLOR][/COLOR] *Only works with bootstrap. Prompts Superuser on first use.
Updated/fixed email client for Yahoo mail users
New Eclipse Launcher! You want fast? Here you go!
Added "LTE" sign to 4G status icon
Increased WiFi [COLOR=#812528 !important][FONT=inherit !important][COLOR=#812528 !important][FONT=inherit !important]scanning[/FONT][/FONT][/COLOR][/COLOR] interval from 2 to 3 minutes
Cleaned up some theme images
Updated Google Apps
Added Wifi-Tether app in Eclipse Parts
v1.0 - 2/14/12
Initial Release
_-updated-_
Download:
how to install:
General Overview
Deodexed
Zipaligned
Bloat Removed
AOSP/CM7 mms
AOSP music
AOSP gallery3D
Eclipse Launcher2
CM7 file manager
AOSP/CM7 Email
AOSP car/desk dock
AOSP news & weather
AOSP calendar
AOSP Sound Recorder
Custom Blur Camera
DSP Manager
Eclipse Parts
Misc prop edits
Custom Host File
Busy Box
init.d support
Eclipse Wallpapers
ICS clock widget
Wake on volume
Known Issues:
Extras:
Changelog:
v1.3.1 - 4/28/12
Added D4 support
v1.3 - 2/25/12
v1.2.1 - 2/22/12
v1.2 - 2/20/12
v1.1 - 2/20/12
Updated Google Apps
v1.0 - 2/14/12
Initial Release
