cool.gautam
The first custom ROM ever made for Micromax funbook Pro!
Features :-
1. Init.d Support
2. Pre-Rooted (SuperSU form Chainfire)
3. Zippalligned all the APK's ( Better RAM utilization )
4. Added Bash - Useful for Scripts
5. Hardware Acceleration Enabled
6. GPU UI rendering
7. Adrenaline Boost - Best Ram Script
8. Lot of Build.prop tweaks
9. Battery Tweaks ( Immense Battery Backup now )
10. Added hosts file - No more advertisements
11. Replaced Stock launcher with Apex Launcher
12. Removed Gapps such as Gmail, Youtube and Maps. Can be downloaded from market
13. Added ICS Bar Hide Mod
14.Added Nano
15. New TCP buffer values for better downloading/uploading and Internet performance
16. Increased overall touch responsiveness
17. New RAM Min-free for auto-killing apps incase RAM memory gets full-Now no more need of task killer
18. Enabled power collapse and forced sleep for better battery backup
19. Moved dalvik cache to /cache partition for massive boost in performance
20. SD card cache value set to 2048 for faster loading of apps on sd card
21. New values for Dirty ratios, OOM ADJ for increased performance
22. New Swappiness values for more swappy funbook
23. Added Beats audio
24. Integrated Super smooth scroll mod
Screenies:-
Uploading....
How to Flash this ROM?
This ROM is flashable via CWM recovery
Note: First make a backup before flashing this ROM, just incase
1. Reboot to recovery
2. Wipe data/ Factory reset
3. Wipe dalvik cache in advanced menu
4. Install zip from sd card and locate this zip and flash!!
5. Reboot system
6. Done!! Enjoy
FAQs
1) Not Able to see ICS bar below
A-- > Default ics bar mode is set to fullscreen mod for gaming. To change go to settings-> Display-> Fullscreen Mode--> Normal
2) Getting "Servor Error" in Google Play Store
A--> Download the latest market here com.android.vending_3.8.15.apk
a) Install the apk
b) Go to settings-> Apps-> All -> Google Play Store --> Force stop & then Clear data
c) Go to Apps->All-> Google Services Framework--> Force Stop & clear data
d) Reboot
3) UI is of phone
A--> Go into Apex Settings->Homescreen Settings--> Scroll down to UI Options--> Tick on Use Tablet UI Mode
Disclaimer : By downloading the rom you agree that after effects of installing the rom will be your own liabiliy. I will not be held responsible for that.
Link To ROM -- > TechTabv1_by_gautam.zip
JUST HIT THANKS IF YOU LIKE THE ROM
Features :-
1. Init.d Support
6. GPU UI rendering
14.Added Nano
Screenies:-
Uploading....
5. Reboot system
6. Done!! Enjoy
FAQs
a) Install the apk
d) Reboot
3) UI is of phone
