Root [ROM] UPDATED 2012/09/4 CyanogenMod 7.2
Swisaiahag
CyanogenMod 7.2 :
Issues:
What's Working (V1.30):
  • Wifi
  • 3G/Data
  • Rotation (Accelerometer) Works with 50% of Huawei M835s (Mostly Synaptic Touchscreen Androids for Some Reason)
  • SMS/MMS* (Recommend you set APNS/Backup APNS Before Flashing Than Restoring AFter
  • GPS
  • Keyboard
  • Dialer/Contact
  • Market (Google Play Store)
  • Camera/Video Recording
  • Music
Links:
gApps :
MMS Fix :
(Flash With Ultrajack)
Notes :
Audio Distorts when volume is set over 70% (See ScreenShots for Recommend MAX Volumes)
Set Custom Equalizer in DSP Manager
Set Graph as it the Screenshots
ChangeLog :
v1.20
  • Changed base rom
  • change bootanimations
  • fixed dialer,music player,contacts,keyboard,camera
  • fixed lcd density/build.prop tweaks
v1.25
  • fixed gps
  • buil.prop tweaks
  • new bootanimation
v1.30
  • NEW Bootanimation with Sound (I did NOT create it i found it on xda forums
  • Fixed Camera
I love the new animation on boot up...lets see how the phone works though :) you should definitely improve this though...at least the bugs...and i think this will be an awesome rom
I fixed all bugs I mentioned . Only problem is I noticed GPS doesn't work. I'm updating links tommarow .hopefully. .
EDIT: IGNORE THIS POST, didnt pay attention to the CM7.1RC1... saw CM7 port then went to the issues/working list first... :/
Im a bit confused...
Using the u8150 CM7 nightly from 9-02-2012, the only issues so far I have noticed are:
Accelerometer (Screen Rotation)
Roaming notification flashing (in the notification bar)
Backlight for the hard buttons doesn't work
Now, I don't use this phone with service, its setup for a friend for using GVoice and simple text's and what-not with WiFi
Camera works fine (pictures/video/preview), I didnt notice any lag/issues with the lockscreen, the keyboard looked just fine, didnt check the dialer, will have to later... The touchscreen seems a bit stiff
Actually you are correct. That rom works but you cannot send MMS. I have tryed to fix it but it wont work.
I cant find it now, but there was an mms fix for CM7 at one point... and its fixed in PG's rom...
That being said, did you manage to fix the issues I listed? and how? (if you did on thee 9-02 release that is)
EDIT: another "bug" :D the IDEOS image upon boot on the m835 :X
Yea I fixed. the keylights for that rom(all I had to do for keylights is to theme the lense lockscreen in uptake kitchen lol). and the mms was the only thing left to fix. . but as for this rom everything works (with minimal bugs) . ..as for the ideos image you have to edit boot.img. which idk how lol. .
Thanks, got a link for the kitchen? Did a simple google serach but got nothing... useful that is :/
thats one bug off my list I guess :D
I just cant go back to older versions of CM7 after all the stuff thats been backported into it from ICS/JB (not so much JB), and some features that where fixed and re-added :D
Runs like a champ for me besides the mentioned issues
sorry i meant UOT Kitchen Lol (Auto-Correct did that )
i guess so , this is for people who want a functionally port for everyday use .
Ah, thanks :D
I want a functional port for everyday use, got it as well :D just dont use Phone/Data (cellular) and it works fine (besides what I listed)
All otherwise, ill use your yours or PG, thanks again!
im going to try to figure it out.
what rom are you coming from ?
you can try flashing v1.0 then updating to 1.30 ?
thats wierd i can get it to rotate on my phone but on no one elses . i tried it on my moms phone . i even restored a backup on to hers . can someone try the original and tell me how it works for them . and does it make adiffere if i flash with CWM 5.0.2.8 for IDEOS
Hmmm I tried the MMS fix it It works perfectly while in clockworkmod but when i try to download an mms picture it still wont download. Any ideas?
