D
Deleted User
Guest
Welcome to: GamerROM Classic
Well it's time to remaster a OLD OS and port it to the Nexus 6, if you aren't aware of what GamerROM Classic is...I will explain!
Introduction:
GamerROM Classic brings back the old memories where gaming started leading up GsmerROM Classic 2 this version is the 1st of it's kind to bring gaming forward with unique features you never saw in newer GamerROM OS's, with light ram usage you will enjoy the fast and light speeds of day to day gaming!
Features:
• Amazing File Management Powered by Google Files.
• Fast & Secured OS.
• Optimized for the Nexus 6 (shamu) hardware.
• OTA Updates (get updates from me Over-The-Air) and more.
IMPORTANT: Due to the Nexus 6 limitations, if you already decrypted your Nexus 6 (shamu) device, be aware that upon installing this OS, your decrypted Nexus 6 (shamu) will be re-encrypted regardless on the method you have used to decrypt your device. What does this mean?....Well this means if you attempt to install a newer OS beyond CM15.1 you will lose access to use Android Pie until you decrypt your Nexus 6 (shamu) again.
We highly RECOMMEND to backup any data if your planning to switch from this version of GamerROM to a different rom beyond CM15.1. We do not take any responsibility for any inconvience this OS has caused you, you are 100% responsible if your decryption is resetted or your Nexus 6 (shamu) becomes damaged or bricked!
Download: https://play.google.com/store/apps/details?id=com.gamerrom.downloader
OS Officially Released On: 05/28/2019
Version: v1.0
Build Status: Nightly
Updated On: 05/28/2019
Introduction:
Features:
Version: v1.0
