[ROM]-v8.1.0 GamerROM Orion™ Pro v1.30 Nexus 6P (angler) Updated On: 10/25/2019!
  • Start date Start date
Do you like GRO?..Why not give us a rating!
  • Votes: 0 0.0%
    Votes: 0 0.0%
    Votes: 0 0.0%
    Votes: 0 0.0%
  • Total voters
    1
D
Deleted User
Guest
Welcome to:
GamerROM Orion™ Pro
For the HUAWEI Nexus 6P (angler)!
Trailer:
RATE THIS OS: If your using the Android Forums application, this thread has a dedicated poll to rate and give feedback based on your vote to help improve the OS overtime, unfortunately due to the application not supporting polls yet, you will need to vote on the website itself!
Well this is very good news i upgraded my device from a Nexus 6 (shamu) to the Nexus 6P (angler)...We are dedicated to bring gaming to the next level so here is our features you will be excited to see:
Features:
High Horse power for your gaming needs
• Innovative features to keep you going
• Fast & reliable connection speeds
• Google Fi Partnered
• Block ads using our modified AdAway app
And much more.
Bugs:
* you tell me
OTA (Over-The-Air) Updates Notice: This OS supports our deicated OTA (Over-The-Air) update service, this means you will recieve all future updates within the "OTA Updates" application 1st before it's pushed out and the thread is updated.
Encryption Notice: This OS has it's encryption disabled, before it was enabled and caused the OS to always encrypt or request password to run android, once you are unencrypted you will no longer have issues from using GRE or GRO no matter what and if you choose to decide to try another non GROS ROM you will encounter ENCRYPTION issues untill that dev patches their rom with Magisk pre-installed in their kernel NO EXCEPTIONS this is the only way i could fix this issue and so can others!
Download: https://play.google.com/store/apps/details?id=com.gamerrom.downloader
Join our discussion: https://t.me/GamerROM
Version: v1.30
OS Official Release Date: 6/6/2019
Latest Current Security Patch: October 5, 2019
Notice: Before you install we highly RECOMMEND you to do a full complete clean install as dirty flashing can cause your apps or even system apps to stop funtioning properly, we advise you to backup any data you wish to not lose during this process such as apps, contacts etc.
Changelog(s):
• Added GR Chat.
• Applied updates from lineageos src.
• Applied security patch "October 5, 2019" update.
• Updated GR Settings to v8.9-20191023
• Updated android system webview.
• Removed GCS.
• Reverted Wallpaper back to stock lineageos.
• Bug fixes.
• Applied Security Patch "September 5, 2019" update.
• Removed Google Opinion Rewards you can now install via gapps as you like.
• Improvements to system stability.
• Improvements to system performance.
• Updated all available built-in apps to their latest versions.
• Removed GR TV since this is an older build an no longer being supported via OS Updates, you can purchase GR TV for $4.99+tax on our website.
• Improved thermal-engine.
• Improved graphics.
• New bootanimation same look but new design!
• Added Google PDF Viewer.
• Applied updates from LineageOS src.
• Removed GR TV since we're not really updating it anymore.
• Updated Android System Webview.
• Improved RAM usage.
• Improved Dalvik VM.
• Improved system performance.
• Updated GR Settings (L Speed) to v2.0.9.
• Fixed an issue with OTA Updates no loading up any info about updates etc the server deleted the ota.xml file and thus update fixes the issue on the OS end of the situation.
• Removed all Google calling and messaging apps and reverted back to stock apps (to enjoy these features consider upgrading to GRE Pro).
• Added GR TV.
• Replaced old GR Settings apps with a new GR Settings app powered by L Speed.
• Applied security patch "August 5, 2019" update.
• Enabled Force 4X MSAA on by default.
• Enabled Force GPU Rendering on by default.
• Removed Google Chrome and restored LineageOS 15.1 Jelly Browser.
• Added Android System Webview.
• New and final wallpaper design change.
• Made overall system performance improvements.
• Fixed an issue relating to accents not properly be selected after user selects a different accent from stock accent.
• Added GLTools v4.01 you can now configure OpenGL for your device, but requires root access to use.
Screenshots:
Preview #1:
Preview #2:
Preview #3:
Preview #4:
Preview #5:
Preview #6:
Updated all users must download it manually this will not download via OTS Updates tocdue a server error update v1.22+ has the error fixed.
