[ROM]-v9 GamerROM Classic Pro™ v1.03 Nexus 6P (angler) Updated: 10/15/2019
  • Start date Start date
D
Deleted User
Guest
Welcome to:
For the Huawei Nexus 6P (angler)!
We first started GamerROM Classic on the Samsung GALAXY S4 then we have ported it to the Nexus 6 (shamu)...Now we are porting it to the Nexus 6P (angler) and we are so excited to expand and give users more options and more flavors then before!
Features:
• Fast and classy OS.
• Running on the SNAPSHOT Version of ASOP OS.
• Running Android v9.
• Customize your gaming experience with GLTools.
• Control your device with L Speed and much more
Download: https://play.google.com/store/apps/details?id=com.gamerrom.downloader
OTA (Over-The-Air) Updates Notice: This OS uses OTA Updates to deliver updates over the air and is much more efficient and faster to recieve bug fixes and feature improvements etc.
Current Security Patch: October 5, 2019
Current Version: v1.03
Android Version: v9
Android Flavor: Pie
Android Type: ASOP
Official Release Date: 08/28/2019
Changelog:
• Applied security patch "October 5, 2019" update.
• Updated MusicFX this adds a new equalizer application.
• Updated Android System Webview.
• Added Original Nexus 6P (angler) stock wallpaper.
• Removed LineageOS Updater and now uses Google System Updater.
• Improvements to system performance.
• Removed all apps requiring root access.
• Applied Security Patch "September 5, 2019" update.
• Updated all built-in system apps.
• Removed Google Opinion Rewards.
• Removed GR TV (is no longer supported and you can purchase GR TV from our website for only $4.99+tax USD.
• Improved system performance and stability.
• Replaced Google Gallery Go with LineageOS Gallery.
• Added Google Play Services AR.
• Replaced ASOP Gallery with Google Gallery Go.
• Applied vendor security patch date to the build prop
• Initial release.
