GamerROM Eclipse Pro™ For the Huawei Nexus 6P (angler)
Official Trailer Preview:
RATE THIS OS: If your using the Android Forums application, this thread has a dedicated poll to rate and give feedback based on your vote to help improve the OS overtime, unfortunately due to the application not supporting polls yet, you will need to vote on the website itself!
Features:
• Fast & Secured OS to keep you safe from thief's.
• Full LineageOS ASOP Experience Supported with its uniques features we implemented..
• Fast connectivity for the best connection to our servers.
• Create your own Media Server with our new DLNA Media Server feature.
• Screen Record you screen and show off your amazing gameplay's.
• Manage RAM Management with Task Manager.
• Fully Optimized for the Nexus 6P hardware.
• Experience a Full Pixel Experience OS!
• No FBE (File-Based-Encryption) needed as it doesn't utilize it!
• Better performance then the Nexus 6 (shamu) using the Nexus 6P hardware and much more.
IMPORTANT NOTICE: Before you install this OS keep in mind the following warning...This OS has Google Apps pre-installed and no need to install your own gapps package, if you plan to install a gapps package the OS may fail to boot YOU HAVE BEEN WARNED!
Notice about root: root is only supported by using Magisk in this build we included the app in the build all you need to do is update Magisk via recovery.
Notice about encryption (MUST READ): I encountered a new issue with the newest security update, this can be fixed by performing a full factory reset in your TWRP recovery. Just reset, then reboot into recovery again then perform the same action and reboot system. This only happens if your device was previously encrypted
Bugs:
• you tell me.
OTA (Over-The-Air) Updates Notice: This OS OS longer support over the air updates since we have discontinued the footed version of the OS, we are now moving forward with a stock version but same OS but eithout root apps baked in, you can still root the OS as you please
• Updated all available Google apps to their latest versions.
• Applied updates from lineageos & aicp src.
• Removed root from boot image you will need to manually root if you want root.
• Fixed a bug that cause constant bootloops whenever attempting to change certain developer option settings.
• Removed GR TV since we are not continuing to update the app.
NOTICE: if you want a build without root or rooted apps, similar to 100% stock we have now a stock version of this build. The stock build will NOT receive OTA Updates as it is now the final version unless otherwise!
• Updated Calculator & Google Calendar.
• New Music Player.
• Fixed a bug with RAM.
• Applied updates from lineageos src.
• New LineageOS Recorder Beta.
• Improved app installation performance.
• Improved Fast Charging.
• Improved system performance.
• Updated GR TV to v2.0.20.
• Disabled Low ram mode.
• Fixed a bug that caused the OS to crash on low memory (hopefully).
• Added GoogleTTS & Accessibility Suite.
• Updated Google Play Services, Google Play Store, Google Dialer, & YouTube.
• Replaced Gmail with Gmail Go.
• Replaced ASOP Gallery with Google Gallery Go.
• Updated GR Settings (L Speed) to v2.0.9 if you do not like the ads popping up just enable adblocking your choice but developer will not receive income consider donating if you choose to use adblocking via AdAway.
• Updated Google Keyboard.
• Updated Google Chrome.
• Updated YouTube.
• Set OS to low ram mode.
• Enabled Force 4X MSAA by default.
• Enabled Force GPU Rendering by default.
• Made adjustments to dalvik vm.
• Added GR TV Powered By Titanium TV.
• Improved offload audio.
• Fixed a bug with the launcher when enabling Kill activities.
• Added GLTools v4.01 you can configure our new engine CryoWare Engine™ for games and applications this does require root access to use.
• Added Back Google Fi v18.
• New non ASOP Music Player from Sony Xperia devices.
• Fixed other miscellaneous bugs.
• Fixed a issue with GR Settings requiring app update when a update isn't needed.
• Added Google Maps Go and Navigation for Maps Go.
• Added Google VR Services for VR features.
• Updates Carrier Services.
• Removed Google Search you have the chiice to download it from the play store.
• Added AdAway v4.2.8.
• Updated GR Settings with L Speed v2.0.8.4.
• Applied updates from lineageos and aicp src.
• Made some improvements with performance.
• Updated all available apps.
• Removed ASOP Camera and replaced it with Google Camera v6.1 Pixel Version.
• Added Gmail, Music and Gallery to the build.
• Addrd Pixel Ambient Services for Now Playing etc.
• Added Pixel Visual Core Services to help process images faster and better.
• Applied security patch "August 1, 2019" update.
• Fixed a bug that caused RAM to not be allocated and dump for future processes
• New UI Overhaul
• Gapps now come pre-installed.
• Added advanced reboot options in developer options.
• Added status bar to Settings.
• Added accents option in display settings.
• Added color settings in display settings.
• Added Now Playing in ambient settings.
• New always-on setting.
• GR Settings is now officially supported by LSpeed.
• Fixed a bug that caused an issue with the LED now lighting when notifications pop up or when charging your device.
• Other OS Improvements and feature add-ons.
• Removed Google Fi.
• Removed Smart Manager due to it failing our performance tests.
• New launcher overhaul.
• Removed FB Services.
• Updated Calendar.
• Replaced old camera with Google's Camera v6.1 this bring google's pixel 1 features to the nexus 6p.
• Removed Android System Webview and replaced it with Google Chrome Webview.
• Replaced old Browser with Google Chrome.
• Made improvements to thermal-engine.conf.
• 2D & 3D graphics will now render in the GPU instead if using the CPU to render them.
• Set Dalvik-Cache heapgrowthlimit from 192m to 256m.
Notice: in this update is our major update that brings a similar experience of the Pixel Experience view more changes below:
• Replaced the ASOP Keyboard with Gboard Keyboard to resemble the pixel experience.
• New default accent is the Pixel Accent.
• Added Google Fi for Google Fi customers.
• Added GR Reboot this will now allow you you to open and have more power options requires root access to use.
• New bootanimation same version but now in dark.
• New Wallaper design (without our GR logo).
• Added new features this include replacing the following: Messages, Phone & Contacts with all versions using the google based versions of the apps.
• Gallery has been replaced and redesigned with a new UI.
• Calclulator has been replaced with the ASOP Stock Version to minimize app updates.
• New Music app and redesigned and optimized for GR OS.
• New DLNA application just click and open and a instant media server will now appear for other devices supporting media server playback.
• Added substratum helper & key services .
for theming.
• Added new Facebook services to help other services utilize the official fb apps to login into faceboo easier (beta).
• Fixed a bug that caused apps to either load slowly or to have a bootloop or not boot at all.
• Improved dalvik vm.
• Fixed a bug that caused the keyboard to press a alt character then the desired selected character.
• Added OTA Updates (we can now send updates over the air).
• Improved Dalvik VM.
• Updated the Gallery application.
• Added Google Live Wallpapers v9.
• Improved rendering.
• Updated Google Clock to v6.2.
• Added our new DLNA app (create your own server toplay media on other devices).
• Storage manager is now on by default.
• Updated Calendar.
• Added new gallery app it now supports new video formats and with a new design and features.
• Added a new screen recorder you can now record your screen anytime you want.
• Set heapsizelimit to 256m out of the heapsize 512m for applications.
• New redesigned material style wallpaper.
• Improved jpeg capture format quality.
• Improved cellular & Wi-Fi signals
• Improved connectivity with ctOS®Network online servers.
• Improved media streaming services.
• Removed FM Radio since logging into google will soon be required by it's developer.
• Updated browser with new permissions and bug fixes.
• OS Improvements.
• Updated Google Calculator to v7.7
• Added Google Search Lite.
• New Launcher.
• Added New Terminal app (can be enabled in "Developer Options")
• Restored the Ad block hosts file to block ads.
• Adjusted Dalvik VM.
• Removed all init'd files but you can add your own!
• Fixed a bug that casued OS to hard crash and perform a hard reboot when their is not enough ram to run the OS.
• New music player application.
• New calendar application.
• Adjusted Dalvik VM (weare experimenting with this to ensure stability and performance).
• Removed hosts file so ads can run, however if you want you can run the systemless adblock module in Magisk (also in testing).
• Updated GR Settings with the new smartpack updates.
• Applied updates from lineageos and AICP src.
• Updated Android System Webview.
• Polished the launcher up a bit.
• Fixed an issue when the OS boots it gives a black screen before opening the launcher.
• Updated Google Connectivity Services to v3.5.
• Applied recovery footprint update to build.
• Removed Chrome and added a New Built from scratch ASOP Material Browser.
• Added New overlays to "/system/vendor/overlays" however these are not yet accessible through settings yet.
• Readded back the CPL Launcher.
• Improved Performance.
• Applied Security Patch "July 5, 2019" update.
• Reverted all apps relating to messaging and camera back to the old stock look till we fix the current crashing issues with them.
• Updated Contacts.
• Updated GR Settings with a new package name and powered by Smart Pack.
• Added init'd support to ramdisk of the kernel.
• Updated Messages.
• Applied update to kernel,is now upgraded from AICP SRC APR 2, 2019.
• Added GR Settings to build for kernel management.
• Updated the messages application.
• Updated Messaging, Phone,Contacts & Camera to google apps.
• Updated the Desk Clock to google's desk clock.
• Updated the calculator to googles calculator.
• Replaced the jelly browser with Google Chrome.
• Set all cores min freq in build prop to 384000.
•Improved audio sampling.
• Scrapped our old Task Manager and integrated our new Smart Manager powered by Boost+.
• Updated Security Patch to June 5, 2019 from google!
• New wallpaper design.
• Removed Action Services as we completed the test!
• Updated the hosts file to add more adverts to be blocked.
• @android/framework-res/assets/ we added few new assets to sounds and webkit.
• Added Action Services and Connectivity Health Services to for further testing purposes to help and give you a better experience.
• Added Google Opinion Rewards back into the build.
• Improved bootanimation fps.
• Improved GPU/CPU rendering.
• Applied updates from lineage os src.
• Fixed a API dectection issue with the launcher.
• New CPL Launcher this contains no ads and is a mod of the PIXEL Launcher (is updateable throught the playstore).
• Completely got rid of the AICP Experience and switced to LineageOS ASOP 9.
• Redesigned wallpaper.
• Added LineageOS Terminal (you can enable or disable this feature in "Developer Options").
• Added Android Accessibility Suite for users with disbilities who needs it.
• New bootanimation.
• Updated Magisk Manager.
• Updated Google Opinion Rewards.
• Added Spectrum Support.
• Added the Spectrum App to select profiles for bettery battery life.
• Fixed a bug where out if random the battery woukd still die wheb ut hits 50%
• After noticing intense battery drain we made some cut backs to the AICP Experience, this includes the following: Removing Aicp Extras, Removing all overlays, and updating the kernel to franco kernel.
• Fixed a battery drain bug.
• Replaced Stock AICP Kernel with Franco Kernel.
• Applied Magisk Into kernel ramdisk you no longer need to reflash magisk's su binary as it's pre-installed.
• Added Task Manager to help you manage, kill your apps and help you free ram and view your resources.
• Removed AICP Extras.
• Removed Omni Jaws since it cannot be accessed without AICP Extras.
• Removed all overlays.
• Updated FM Radio to v1.3.5.
• Added AICP Extras to the OS you can now customize the OS as you like.
• in AICP Extras added addtional links to the Original AICP to support the team and get the original AICP OS non gamerrom.
