PRallday168
HUGE THANKS TO jb2kred FOR THIS !!
Original thread :
http://forum.xda-developers.com/showthread.php?t=2270831
Hi I have made a fully ported version of paranoid android 3.9+ for the Kindle Fire HD 7(Tate)
this does use hashcode's kernel and i will always update rom when changes are needed this is not the same port as in the other thread this is a fresh build from source the pa setting menu works and has the same bugs as hashcodes rom it does use his new 1.5Ghz kernel.
Links:
pa_tate-3.96-20130813.zip
Rom: http://goo.im/devs/ParanoidAndroid/r...6-20130813.zip or Download from GooManager
Md5: 318a5ae4b0b67dc9c10518a9ce72c882
[13/8]Hashcode / Wickets Rotation Fix for Trebuchet
[13/8]Most Recent Changes from PA Sources
[13/8]Enjoy
pa_tate-3.95-20130808.zip
Rom: http://goo.im/devs/ParanoidAndroid/r...5-20130808.zip or Download from GooManager
Md5: 2be1b495f9ed93da467fa774ccda51ed
[08/08]More Fixes
pa_tate-3.94-20130806.zip
Rom: http://goo.im/devs/ParanoidAndroid/r...4-20130806.zip or Download from GooManager
Md5: b4708746939ffd01b8dd8b7a9f6b4906
[6/8] PA 3.94 more fixes
[6/8] Newer Changes to Hashcode's Kernel and Sensors
pa_tate-3.92-20130803.zip
Rom: http://d-h.st/hXx
Md5: e70bbe6bb7c7489f7ba10aaaa0a67c4a
[3/8] More PA fixes for 4.3 No longer need superuser to be flashed and some other fixes
pa_tate-3.91-20130802.zip
Rom: http://d-h.st/6KL
Md5: 7cda3028974049e3456021b63502c3a5
superuser-4.3-beta3.zip Must flash to get Hybrid working
SuperUser: http://d-h.st/mnW
Gapps: Use ParanoidOta to download newest Gapps Seems Easier.
pa_tate-3.90-20130801.zip
Rom: http://d-h.st/i6J
Md5: f4b807546527eb8f3ba0fcbe3a2eec6b
pa_gapps-full-4.3-20130731-signed.zip
Gapps: http://d-h.st/Ra2
[1/8]PA 3.90 4.3 Sources Used
pa_tate-3.69-20130729.zip
Rom: http://d-h.st/Fmy
pa_tate-3.69-20130729.zip.md5sum
MD5: http://d-h.st/DWp
[29/7]New Hashcode's Changes and Kernel
[29/7]PA 3.69 Refresh
pa_tate-3.60-19JUL2013-204653.zip
Rom: http://d-h.st/dfv
pa_tate-3.60-19JUL2013-204653.zip.md5sum
MD5:http://d-h.st/luV
pa_gapps-full-4.2-20130715-signed.zip
Gapps:http://d-h.st/0sr
[19/7]Using Updated Hashcode Kernel / Device
pa_tate-3.60-15JUL2013-142447.zip
Rom: http://www.androidfilehost.com/?fid=23043426517779398
[15/7]Using Updated Hashcode Kernel
pa_tate-3.60-25JUN2013-095604.zip
Rom: http://www.androidfilehost.com/?fid=23017610006233795
[25/6]Halo Added to Rom
[25/6]Using Updated PA Sources
[25/6]Using Updated Hashcode Kernel
pa_tate-3.56-30MAY2013-175954.zip
Rom: http://www.androidfilehost.com/?fid=22979706399752859
[30/5]Using Hashcodes Latest Kernel upto 1.5 Ghz
[30/5]Ported CM10.1 Performance Settings into PA Settings So able to set CPU Speeds
pa_tate-3.56-24MAY2013-175954.zip
Rom: http://www.androidfilehost.com/?fid=22964708692722950
[25/5] Rebuilt with Latest PA Source's
pa_tate-3.50-17MAY2013-161700.zip
Rom: http://www.androidfilehost.com/?fid=22964708692721665
[17/5] Camera now working again
pa_tate-3.50-16MAY2013-180607.zip
Rom: http://www.androidfilehost.com/?fid=22962010882834579
[16/5]Now Uses Hashcode's new kernel with semi mic input working
[16/5]Removed advanced Item from Settings menu
[16/5]Changed dpi setting for settings menu
[16/5]Camera seems to be broken in this build I am looking into this
pa_tate-3.50-08MAY2013-160607.zip:
Rom: http://www.androidfilehost.com/?fid=22946563261203439
Gapps:
pa_gapps-full-4.2-20130522-signed.zip - Newest Now Working
http://www.androidfilehost.com/?fid=22964708692722647
pa_gapps-full-4.2-20130427-signed.zip
http://www.androidfilehost.com/?fid=22946563261203438
Please use and let me know if you have any problems
Jb2kred
Original thread :
Links:
[13/8]Enjoy
[08/08]More Fixes
Gapps:
Jb2kred
