Root [rom] [wip] wp7/8 rom v2 [12/20/12]
azoller1
Android Expert
DISCLAIMER: IM NOT RESPNSIBLE IF YOU SCREW YOUR PHONE UP!!! JUST FOLLOW INSTURCTIONS!!
Want windows ui on your lg spectrum? well your at the right place!
Features:
Debloated
Zipaligned
Rooted
Deodexed
WP7/8 Bootanimation
WP7 Music
WP7 Dialer
WP7 Lockscreen
WP7 Calculator
WP8 Launcher
WP8 Notifications
WP7/8 Messaging
Build prop tweaks
Other tweaks
Smooth
Clean
Downloads:
VERSION 2
Installation:
1. unlock bootloader
2. download the rom
3. reboot to CWM
4. wipe data/factory reset
5. go to mounts and storage and mout system
6. format system
7. install the rom
8. optional: wipe cache/dalvik after you flash it
9. reboot and succeed
Changelog:
V1
-Initial Release (IN BETA!!!)
V2
-updated windows 8 launcher to latest version
-added init.d support
-added init.d tweaks
-updated busybox
-removed metro ui seemed to have issues
Issues:
Might have some fc's but not where you cant use it, this rom is still very stable but with some issues i need to fix when i have more time
Features In The Future:
Totally revamp ui to make it just like a windows phone 7/8
Add init.d tweaks for better battery life
More build prop tweaks
Add more apps for a better windows experience
Theme some LG apps for a windows look
Other things like fix issues
Thanks everyone here for doing all the hard work to get cwm, unlocking bootloader to get roms available on our lg spectrum!, neph, tdm, playfulgod, death2all, and everyone else at xda by making all of these apps and tweaks!
Logging into your account should work if thats what your asking and contacts should show up they did for me
I'll make an update tomorrow with updates launcher and some better tweaks or more tweaks and maybe a better boot animation, maybe some theming well see
I flashed it over WP7 and everything that I use works great.
The camera is seamless and I use Launcher Pro Plus so I don't havr much input regarding the home screen.
Haven't had time to check out the BT issue but I am considering getting a BT transmitter that plugs into the headset jack.
It's good to have a ROM that isn't so cutting edge that it is very stable.
Too bad L (Licking) G (Groin) can't seem to be human enough to release the real source code for the ICS kernel.
EFFING CORP GREED....
Any way, thanks for the devotion to the cause.:D
