Root [ROOT][GUIDE][ONE CLICK] Asus ZenFone 2E/2/Z00D/ZE500CL/550ML/551ML
cotylee1991
Member
I am not responsible for bricked devices, dead SD cards,
thermonuclear war, your kids, your house, your wife, or you getting fired because the alarm app failed. Please
do some research if you have any concerns about this
before using it! YOU are choosing to make these modifications, and if
you point the finger at me for messing up your device, I will laugh at you.
A lot.
This guide will show you how to root your Asus Zenfone 2E, in one click. I have tested, and confirmed working on the AT&T ASUS ZenFone 2E/Z00D/ZE500CL
1. Make sure you have ADB Drivers, FastBoot Drivers, and your devices drivers installed. If so, skip to step 3.
2. Install ADB Drivers and your device drivers by downloading this.
1. Run it (Require administrator privileges)
2. Press Y/Yes to install ADB and Fastboot or N/No to skip
3. Press Y/Yes to install ADB system-wide or N/No for current user only
4. Press Y/Yes to install Device Drivers or N/No to skip (Device must be connected via USB Debugging)
5. Continue Driver installation - DONE!​
3. Connect your device with USB Debugging enabled.
4. Download the root files HERE.
5. Unzip to dekstop.
6. Open the folder, and double click on the file labeled "Root_zenfone.bat".
7. It will open a Command Prompt window, your phone will boot into fastboot, allow the process to finish, and you're done!
8. Phone will reboot and you have root!
NOTES
DO NOT
update SuperSU binaries if you want to update to a future OTA update, that is if Asus releases a 5.1 update.
DO NOT uninstall bloatware, as if an update were to arrive, it will brick your device. I suggest "freezing" the apps you don't need with Titanium Backup or Disable Application.
If you want to unroot, run Xoa_root.bat in the file folder.
Coty Thomas
DEVICE: Asus ZenFone 2E rooted with ZenFone O.C. Root on 5.0.1
I Pay $20 A Month, What About You...
