Beerkan
Ok folks, it's never been easier to root your phone than it is right now. Not only that, but follow this upgrade process, and you will have a rooted phone that runs Apps2SD by default. (Where apps are stored on the SD card rather than in internal memory). You will have up to 1GB of storage for apps depending on the size of your SD card.
Anyway, it only requires 3 simple steps to rooting your vanilla Android 1.5 or 2.1 Spica/Lite/Portal phone. (if your phone is already rooted, you can follow this guide to install the lastst firmware, and then re-root your phone after.)
If you already have a 2.1 android firmware you're happy with, but just want to root your phone, then you can jump to Rooting your Phone and begin using Apps2SD.
There are many threads on how to root your phone, but they all need a few basic software items.
Firstly you'll need the latest Samsung Android 2.1 Phone firmware Here:
(currently as of this link, August I570EXXJH6)
Get it Here I570EXXJH6 (75Mb)
(Password samsung-firmwares.com )
Next you'll need the software to install it. Commonly referred to as Odin and the install file for the Spica/Lite/Portal.
Get it here. Odin v4.03 & spica_jc3_ops Files
Lastly, you'll need the update that will finally root your phone.
You can read more about the Root update, and download it here..
N.B. You're looking for the link to the file. i5700_LK2-08_PDA.7z
LK2.08 Root for Original Firmwares
Once you have all these files, extract them into a single directory.
If you haven't installed the USB drivers that came with your phone, you can either use the USB drivers than came on the CD, or if you want the latest USB drivers, install Kies Samsing PC Software
Have a look through this video from Youtube on rooting your phone, for a rough idea of what's involved. Be aware, the the video refers to earlier files, therefore use my up to date versions instead.
Root Guide
Below is my brief guide on installing firmware, however please read up on using Odin and installing new firmwares available in many other threads.
If you wish to backup your phone and it's details see my earlier post here, aimed at beginners and non-rooted phones.
Beerkan's Quickie Backup Guide
N.B. Make sure your phone is NOT pattern or password protected when it starts up.
To start.
Do NOT have the USB cable plugged in, until necessary.
Also DO NOT have KIES or the NPS software running.
Extract ALL FILES from I570EXXJF6.rar to single directory.
Extract Odin v4.03 & spica_jc3_ops Files into this directory too.
Run odin.exe
(You may need to run in Administrator Mode. RMB on Odin, and choose properties -> [x] Run in Compatability, and choose WinXP SP3. Click OK. Then, RMB again, on Odin.exe and choose RUN AS ADMINISTRATOR. If you get Ignore path warnings in Chinese, just click OK/Cancel.)
On the right hand side windows Select these files.
OPS = spica_jc3_ops
One Package = I570EXXJH6.tar
Left hand side window
[x] One Package
[x] Reboot (ticked)
[x] Protect OPS (ticked)
[x] Reset Time (ticked) 300
[ ] Debug (not ticked)
Power off the phone.
Now Press and hold down in order
"Volume Down + Camera Key + Power On"
Might take a couple of tries.
Wait till you see Downloading Screen, come up.
Connect phone to PC.
Watch top left in Odin for COM Port mapping. When the phone is correctly connected this will display which com port the PC is connected to.
If this does not happen, ensure you have USB drivers installed. Odin can be a bit of a git, so you may need to try other things. Unplug the USB and re-insert it. Try another USB port. Rebooot the phone, put in into download mode again, try rebooting PC and start again.
When you DO see COM Port mapping in Odin, click Start.
Takes about 3 mins, and you will see a green progress bar.
Wait for your phone to reboot, about (2 mins) with No Sim message.
Odin should say PASS!
Disconnect phone USB cable from PC
Close Odin.
Wait for phone to boot, then power off phone and insert SIM & SD.
N.B. If the firmware defaults to Dutch Language after updating, change it with these instructions:-
Menu
Instellingen
Landinstelling en tekst
Landinstelling selecteren
English (United Kingdom)
You can power it on, and checkout Android 2.1 if you wish.
Once you have upgraded your firmware, throughly check the phone is all working etc.
Rooting Your Phone and begin using Apps2SD
It is possible to root your phone if you are already using 2.1 firmware. However, you may encounter issues with this root update, because Apps2SD, and specifically your phone, may not work because it will not see previously installed Apps on the phone's interal memory.
To get round this, the best solution, is to lose all your installed apps, delete all installed apps, and install these Apps again. However, you can also install the root update, go into Recovery Mode manually, and clear the cache and dalvik-cache, which should retain your previously installed apps. in this case, you will have Apps installed in the internal memory, AND have new ones installed on the SD card.
I would reccommend deleting all installed apps, clear the caches from Recovery Mode, root your phone and then re-install these Apps so they are installed to the SD.
If you have not installed any new Apps, and wish to now root your phone, you need to perform another upgrade using Odin.
But this time you will use the i5700_LK2-08_PDA file. (remember to extract it into same directory as Odin.) you just downloaded.
N.B. As already stated, rooting the phone to use Apps2SD will require the SD card to be formatted, so backup the SD card contents you wish to keep to your PC.)
To put phone into Download mode. Power off, and then
In Odin on the right hand side windows Select these files.
OPS = spica_jc3.ops
BOOT =
PHONE =
PDA = i5700_LK2-08_PDA
CSC =
[ ] One Package (not ticked)
[x] Reboot (ticked)
Plug in phone and wait for COM mapping to appear. Click start to install root update.
This process will be much quicker, and your phone will reboot.
We now need to put phone into Recovery mode to complete the installation.
To enter recovery mode manually, power off the phone, then press
Vol Down + Call + Power On
We will need to format the SD card with 2 partitions.
1. An ext2 partition to store the Apps onto. (only visible to the phone's OS)
2. A FAT32 Partition for all other files. (Visable via your phone and PC)
Remember, again, you will lose ALL data on your SD card, so backup what you need.
When the phone recovery screen appears.
You will need to do the following:-
Using the 4 way navigation key
Press down and select
Partition sdcard ->
Press OK to select it.
Choose what size you want your Apps Partition (256Mb to 1Gb)
Make 1024M ext2 on SD
Press OK
Now Press Home Key to execute and Partition the SD.
Once formatted, choose Reboot System Now.
Once the phone has booted it will automatically save apps on the SD CARD.
Congratulations. Your phone should now be rooted, and to make life easier, you can install the Android SDK and use Android Commander to add/remove files.
rgds
Have a Beer
Root Guide
To start.
Run odin.exe
OPS = spica_jc3_ops
[x] One Package
[x] Reboot (ticked)
Close Odin.
Menu
Instellingen
OPS = spica_jc3.ops
BOOT =
PHONE =
CSC =
[x] Reboot (ticked)
Partition sdcard ->
Press OK
rgds
Have a Beer
