!!!!!WARNING!!!!!!
This will wipe your phone.
Prep
Enable USB Debugging and OEM Unlocking on your phone
Install ADB Driver
Install EDL Drivers
Restart Computer
Files
ZTE_BLADE_Z_MAX_edl.7z
Archive includes adb and edl drivers for win7 x64
Guide
1. Extract the folder inside ZTE_BLADE_Z_MAX_edl.7z to your desktop.
2. Connect your phone to your computer.
3. Open the folder "ZTE_BLADE_Z_MAX_edl" that you just extracted.
4. Right click on ZTE_BLADE_Z_MAX_edl.bat
5. click run as administrator
6. Press Y
7. Press 1
8. Press 2
9. Press Y
10. Press N
11. Press 1
12. Press 3
13. Press Y
14. Press N
15. Press Q
16. Disconnect your phone from the computer.
17. Press and hold "Power and Vol+" untill the ZTE Logo Appears then release the power button while continuing to hold vol+
18. Once booted into TWRP Recovery, swipe to allow modifications.
19. Tap Wipe
20. Tap Format Data
21. Type yes
22. Tap Blue checkmark
23. Back out to the main screen.
24. Tap Reboot
25. Tap System
"Initial Boot will take some time, and may even reboot"
"If more than 5 mins elapses, press and hold power button to restart device"
26. Setup Android
27. Locate Magisk and open it.
28. Install magisk manager "May have to anable unknown sources first"
!!!!DO NOT UPDATE MAGISK!!!! Only update the magisk manager.
Profit!!!!
Prep
Install ADB Driver
Install EDL Drivers
Restart Computer
Files
Guide
6. Press Y
7. Press 1
8. Press 2
9. Press Y
10. Press N
11. Press 1
12. Press 3
13. Press Y
14. Press N
15. Press Q
19. Tap Wipe
20. Tap Format Data
21. Type yes
24. Tap Reboot
25. Tap System
26. Setup Android
Profit!!!!
