Rooted, but need help before I flash a new ROM
Rcmcivor
I'm a newb so I'm new at this. I rooted my N7 today and installed a (kernel maybe? sorry I don't know what I'm talking about) from poitee using a guide that used Nexus Root Toolkit. Everything went well FWIW but this time I don't have an article to follow so I'm a little lost. I thought what I flashed was what I needed but it isn't, I need to be able to use OTG and charge the N7 at the same time.
Here is what I need. I downloaded the CM10 ROM and have it as a zip. I think all I need to do as before is use Nexus Root Toolkit and flash the zip under advanced utilities. On that site there is an additional boot image that I need after CM10 is in. I need help on what to do with that. I see in advance utilities that there is a place to flash images but I have to specify a partition and I don't know what the answer is to that. I see on the site they give command line code but I was hoping that I could do this with the tool kit... or am I ultimately better working in the command prompt?
Thanks for any help!
Ryan
