Root Rooted Display Calibration Questions/Discussion
Rx, if you are the rooting type, how do you recommend calibrating it?
Many kernels have display tweaking options. For instance, I use franco kernel, and his franco kernel updater app lets you adjust the display. You can also load profiles made by others.
The app display tester can then be used to measure the changes you've made.
Thanks. Scanning...
Edit:
Good results so far. I've underclocked and undervolted my CPU while fixing my gamma issue :)
CyanogenMod has heard our cry. Check this out! :)
attachment.php
attachment.php
No mods necessary. It's under Settings > (under Device) More... > Display calibration > Color calibration.
It starts with the 05-04 nightly and is not in the M6 release.
