Rooted Samsung J 7 keeps Restarting After Hard Reset
zarabib
Hi,
I've just rooted a Samsung J7 Prime G610F using Odin. Primarily because I wanted to recover some deleted files in the internal memory. I succeeded after many times (one click root etc... didn't worked).
Anyway now I've another problem. My phone didn't recognize the pin to unlock. Then I made a hard reset but now the phone keeps restarting!
Please any quick solution to fix this mess?
Thanks in advance
Possibly whatever the root did has damaged or corrupted the firmware, making it boot loop. You may need to reflash it using Odin and the original Samsung firmware.
Thanks for your reply.
I've downloaded the stock firmware to recover my phone but Odin failed. It stuck and didn't want to go in download mode.
I've read that it could be that Odin doesn't recognize the file inside the archives. So I've removed the .md5 extension and extracted the recovery image and finally put it in a new archive (recovery.img.tar)
When I flashed again with Odin I only loaded this archive and it reset my phone. It switched on normally.
My question is,
Should I load also all the files (BL, Cp, CSC, Home CSC) inside the stock firmware to recover my phone totally to its original Samsung firmware using the same method as above (remove md5 extension etc..)?
Also I need to say that neither Kies3 nor Smart Switch are working. My phone isn't recognized.
Please help me to get out of this nightmare!
Download this app into your J7..it will make your fantastic phone being seen by your computer..
Ps..I still wonder how you get your J7 rooted..supposedly that's still not available..I tried that with my mom's phone all night long the other day with the file "root for every one"..wasn't able..good job!!!..any way.
Let me know.
It is possible that your firmware is corrupted. Have you tried to factory reset the phone? if not try that, it might stop your phone from restarting.
