HI,
I bought a new Aztech PlayXtreme - Internet TV hub(ITV101E) and it gives lot of errors, apps don't work properly, they crash most of the time.. youtube app never works.
Some Apps are not able to write to my SD card and I get unknown error.
Would someone be kind enough to help me give info on how to go about rooting the device and which is the compatible custom rom to install and where can I find the instructions to install. Below are the configuration of the device from the website.
CPU ARM - Cortex A9
Frequency - 800MHz
RAM - DDR2-512MB
Storage - NAND 2GB
OS - Android 2.3 (upgraded to ICS)
UI - Android 2.3
Browser - Android
Media Player - DAT MPEG MPE MPG M2V ISO TS VOB AVI MKV MP4 MOV 3GP 3GPP FLC AVI WMA TS M2TS M3TS M4TS M5TS MTS M4V FLV 3G2 RMVB
Music - MP1 MP2 MP3 WMA WAV OGG OGA FLAC ALAC APE AAC M4A AC3 RM
Picture Viewer - BMP JPG TIF PNG GIF
Software Update - Support SD card for software update
External Storage - SD/SDHC card, USB storage support
USB - 2x USB host
SD Card - 1x SD slot
HDMI 1.3 output
LAN - LAN port 1x 10/100Mbps
HDMI
Remote 2.4GHz Wireless Qwerty Remote Control
Voltage 5.0V/2A DC
Dimensions 12cm (L) x 12cm (W) x 3cm (H)
Net Weight 152g
Regards
Gaurav
CPU ARM - Cortex A9
Frequency - 800MHz
RAM - DDR2-512MB
Storage - NAND 2GB
UI - Android 2.3
Browser - Android
USB - 2x USB host
HDMI 1.3 output
HDMI
Voltage 5.0V/2A DC
Net Weight 152g
Regards
Gaurav
