Rooting Guide
KoboUser
Today I'm going to guide you through rooting your Android device and more about rooting!
First off all if you do not know what rootng is or what I can do then you have came to the right place!
So rooting is something most people know about but it can be pretty confusing but I'm going to make it simple!
So rooting is basically by passing your devices security and unlocking your devices hidden power by that I mean it lets you do more than you ever could without root here is some stuff you can get from rooting!
1.Apps unsupported by an unrooted device
2.Modify deeper files hidden in your device such as system files
3.Getting special roms for your device
4.Being able to add special addons for your device
So that's the stuff you can do with a rooted device now to the part where it gets more complex!
When you root your device you are inserting a special file that by passes your devices security and then the rooting will probably start!
Do your probably wondering how do I root my device well there is allot of ways out there that will work some are pretty risky some are OK but if you want a safe one I recommend kingroot it's a app/apk that is safe easy to setup and instantly roots your device search it up on Google :)
But that's not the only way to root your device if you go onto Google and search up how to root your devices name it will most likely come up with some stuff that will help try that if it doesn't work try the above method!
I will list apps that use root that are very useful!
1.SCR -This app requires root but if your a YouTube looking on a way to record your tablets screen this app if a definite!
2.Root Explorer-If you want to mess about with some system files (NO RECOMMENED) this is the app for you!
So there you go that's some stuff to get you started on root and even some apps you can use with it!
Hope you enjoyed my guide Thanks for reading!
