Help "Running services": Do they deplete battery?
cutedroid
Question 1
In Settings>Developer_Options>Running_Services, I see several things that I don't need.
https://imgur.com/a/YKE8Esg
I believe that unnecessary services that run are unnecessarily depleting my battery, leading to a shorter battery lifespan.
I use my fingerprints to unlock, so I'm not sure if I need these services that I see are on the list of "running services":
★ Face
★ Intelligent Scan
★ Iris
Question 2. Do "cached background processes" sap my battery?
I see the following "cached background processes" https://imgur.com/a/vb9EsuD
Here are some that I don't need:
★ Bluetooth
★ NFC
★ Samsung DeX System UI (My Samsung phone is not connected to an external monitor/computer)
★ Google VR Services (I don't need/use VR)
Running Samsung S9 on Android Pie. (My phone is not rooted and not rootable.)
Running services will always use up battery life, but disabling them would be unbeneficial to using your phone
Disable running processes = more battery life and your phone may not work correctly.
Leave running processes alone = phone works as should but your battery takes a hit....
Something to keep in mind is when you're disabling some app/service it might not just be that titled process you're killing off, some of them work interactively with other processes so you might be inadvertently affecting something else. Just use a little restraint, pick one or a handful at time and if that doesn't affect anything after a few days of using your phone, disable a few more. If you do run into a problem you can just re-enable whatever is needed.
But as already referred to, at some point you can disable a whole bunch of apps and your battery life will probably be better but you'll also end up with a smartphone that doesn't have the same functionality it was intended to have.
