Hi all. My S3 won't remember that it's connected to my wifi in my home when it's turned off over night even though I leave the wifi switched on in the notification bar, is this normal?. I have found there is a Wi-Fi timer auto connect function in the Wi-Fi advanced settings, do i need to use this in order to reconnect my Wi-Fi connection after the phone is turned back on in the morning. At the moment when I turn the phone back on it says, Wi-Fi disconnected - poor signal, but when I select my Wi-Fi from the list it tells me the signal is "very strong" but then I have to forget the connection and manually re connect to my rooter every time I turn on my phone on in the morning.....
